Rest_command data input using template
When I enter this code,
service: rest_command.poolaction
action_code: 5
device_number: 1
value: {{states(‘input_number.pool_heater_setpoint’)}}
it saves as:
  • service: rest_command.poolaction
    action_code: 5
    device_number: 1
    value:
    “[object Object]”: null
I’ve checked the template in the template editor under developer tools and it works fine. Any suggestions?
thankyou
Please format your pasted code correctly as per section 11 of the forum FAQ.
You need to quote single line templates.
This is what I put into yaml
  - service: rest_command.poolaction
      action_code: 5
      device_number: 1
      value: {{states('input_number.pool_heater_setpoint')}}
This is what shows after saving:
      action_code: 5
      device_number: 1
      value:
        "[object Object]": null
As I said:
value: "{{ states('input_number.pool_heater_setpoint') }}"
that suggestion returns a string rather than a number and as such, is not triggering the correct downstream response. Is there something further that you can suggest?
Fix your downstream response.
unfortunately, that is not possible. I am feeding instructions to a cloud based intermediary that is then instructing my pool controller what to do. this is the only piece I have not been able to get working… thanks for your help
value: >
   {{ states('input_number.pool_heater_setpoint')|float(0) }}
excellent!. float(0) didn’t work but I changed it to int and success!
with thanks
