rest_command:
unlock_front_door:
url: “https://xxxxxxxx”
method: post
and I have created an automation to run Actions Restful Command: unlock_front_door
but nothing happens
if I copy and past the URL in my browser it woks fine but not in Home Assistant
the logs show
Error: Cannot connect to host xxx.com:443 ssl:default [nodename nor servname provided, or not known]
any help please
thanks
if you paste in a browser, the method is not ‘post’, but ‘get’ .
if the url ends on .com i wonder where that url is. If it’s not yours hosted or on your network, i assume there is some authentication required (which is present in your browser probably, check with dev tools on your browser)
yes the url is.com/
tried get made no difference its like its not being sent at all
error 443 ssl:default [nodename nor servname provided, or not known]
