I’m at a loss here, I’ve search and found some solutions to similar issues but can’t seem to find the solution to my problem. What I currently have is an input_select and a rest_command
- id: set-fan-mode
alias: 'Adjust Fan Mode'
- platform: state
entity_id: input_select.fan_mode
service: rest_command.set_fan_mode
fanmode: >
{% set mapper =
{ 'Vacation':'NOTHOME',
'Automatic':'AUTO',
'Middle':'MIDDLE',
'Low':'HIGH',
'High':'LOW' } %}
{% set state = states('input_select.fan_mode') %}
{% set fanmode = mapper[state] if state in mapper %}
{{ fanmode }}
Changing the state results in two logbook entries, one saying that the Fan Mode has been changed. The second saying that my automation has been triggered. Then after that, nothing happens and I see an error in the home assistant log: “Uncaught TypeError: Cannot convert undefined or null to object”. I’ve tried adjusting the automation from ‘data’ to ‘data_template’ to no avail. What am I missing here?
This proves that rubber ducking works: data_template is the correct part and my command was incorrect: it was supposed to have lowercase ‘cmd’ rather than uppercase ‘CMD’ in it
Well, the input_select can’t be another value so I don’t have to check that one, but I also update the input_select state with another sensor (REST call). The result of the REST call can be NaN. So that’s why it’s nice to know
Wait, you have something that sets the value of an input_select to something other than one of the defined options? That shouldn’t be possible, at least via the input_select.select_option service. So how are you updating it?
No, it tries to set it to one of the possible values. However the REST endpoint that it uses to set the value can return a 0,1,2,3,4 or NaN. I’ve added the condition there to only update the input_select when the value is within 0…4.
