I’m trying to connect to a train-timetable api; https://luasforecasts.rpa.ie/xml/get.ashx?action=forecast&stop=che&encrypt=false which is returning sort-of xml (there is no lise at the top saying “<?xml version="1.0" encoding="UTF-8"?>” and it not returned as “application/xml” in the http header.
The xml looks like:
<stopInfo created="2024-04-21T20:17:23" stop="Cherrywood" stopAbv="CHE"><message>Green Line services operating normally</message><direction name="Inbound"><tram dueMins="2" destination="Broombridge" /><tram dueMins="13" destination="Broombridge" /></direction><direction name="Outbound"><tram dueMins="14" destination="Bride's Glen" /></direction></stopInfo>
When I try to create a rest connection it doesn’t see this as XML so won’t convert to json (i.e. my value_json is blank) but does fill value - but value is limited to 255 characters so i don’t get the whole message.
I’ve added some regex to get these values… but it is getting messy.
Is there a way to force the xml into json? I can make valid xml using {{ ('<?xml version="1.0" encoding="utf-8"?>\n' + (value)) }}
my configuration.yaml
rest:
- resource_template: "https://luasforecasts.rpa.ie/xml/get.ashx?action=forecast&stop=che&encrypt=false"
scan_interval: 30000
- name: "luas xml"
value_template: {{ value_json }}
- name: "luas message"
value_template: >
{{ value|regex_replace(find='.*<message>', replace='', ignorecase=False)|regex_replace(find='<\/message>.*', replace='', ignorecase=False) }}
- name: "luas inbound"
value_template: >
{{ value|regex_replace(find='<direction name="Outbound".*', replace='', ignorecase=False)|regex_findall(find='<tram [\w=" \']*\/>', ignorecase=False) }}
Secondly, if i want to refresh this I can run an automation that calls the service RESTful: Reload can this be tailored so it only calls a specific rest api?
