and I have an automation on it to warn me when its value changes :
- id: public_ip_change
alias: public ip change
platform: state
entity_id: sensor.public_ip
condition:
- condition: template
value_template: '{{ states.sensor.public_ip is defined }}'
- service: notify.notify
It usually works well and as intended.
Except when the rest call stumbles on an error. (timeout, or any other)
In that case, the sensor.public_ip value becomes āunavailableā.
And of course, it triggers the automation.
This is usually very short in time and then the rest call works again and the sensor.public_ip is back as beforeā¦
Which triggers the automation again.
This is very annoying and makes my use-case (beeing notified that my public ip changes) not possible.
You could try something like this for the template condition:
value_template: >
{{ trigger.from_state.state not in [none, 'unavailable'] and
trigger.to_state.state not in [none, 'unavailable'] and
trigger.to_state.state != trigger.from_state.state }}
EDIT: Actually this might be better:
value_template: >
{{ trigger.from_state not none and trigger.to_state not none and
trigger.from_state.state != 'unavailable' and
trigger.to_state.state != 'unavailable' and
Sorry, it was a typo. I meant trigger.from_state is not none, but trigger.from_state != none works, too.
I checked the RESTful Sensor code, and are you sure youāre getting āunavailableā? The code sets the state to āunknownā when the REST query fails. So I think my suggested code would be the following instead:
value_template: >
{{ trigger.from_state is not none and trigger.to_state is not none and
trigger.from_state.state != 'unknown' and
trigger.to_state.state != 'unknown' and
But, to answer your question, what do you mean exactly by āfixā? Iām pretty sure by design the state is set to āunknownā when the query fails. If you would rather it left the state as-is in that case, then you could copy the code to custom_components/sensor/rest.py in your HA config folder and modify it to do what you want.
Oh, youāre probably right about unknown (my interface is in French).
I changed it, Iām waiting for the issue to reproduce.
By fixing I mean, having the ability to just ignore the data points in the sensor where it is unknown.
Would it be possible with a template sensor ? I searched for it but couldnāt find.
But to answer your question, the only way I can think of to not have the RESTful Sensor go to a state of unknown when the REST query fails is to change the code. If you want to have another sensor that ignores this sensorās unknown values, youād probably have to do that with an input_text and an automation, and the automation would probably have to have the same condition as what I suggested for your original automation. Iām not sure itās worth the effort.
But maybe someone else reading this topic will think of something thatās not coming to my mind.
I meant ignoring it directly into the sensor, which would solve the problem at the source.
Iād rather not make a custom rest sensor just for this case, so Iām keeping on trying the āautomation fixā.
The āunknownā didnāt work (I got a notification when waking up), so Iām adding āunavailableā to the conditions, hoping itāll work.
value_template: >
trigger.from_state.state != 'unknown' and trigger.to_state.state != 'unknown' and
trigger.from_state.state != 'unavailable' and trigger.to_state.state != 'unavailable' and
It doesnāt trigger on āunavailableā.
Iāll have to wait a few weeks/months to see if it still triggers on an actual public ip change, though.
For what itās worth, you could slightly simplify it (and make it easier to exclude other unwanted states) this way:
value_template: >
{% set ignore = ['unknown', 'unavailable'] %}
{{ trigger.from_state.state not in ignore and
trigger.to_state.state not in ignore and
This also seems to correctly handle the situation where trigger.from_state or trigger.to_state are none.
