pda
1
Hi All,
I’ve configured my first Rest sensor today, it’s working perfectly.
I’m focusing now on the scanning interval, I would like 2 things to happen:
- Scan the sensor when minute equal 1,16,31 or 46 (4 scans per hour at specific time) - important to me.
AND
- Do not scan the sensor between 22:00 and 06:00 (nice to have)
Just setting the scan_interval to 15 minutes, would not exactly do the trick.
Is that possible, and if so, how complicated is that configuration?
Cheers.
tom_l
2
Set a really long scan interval in your sensor config (e.g. 31556952, one year in seconds). Then use this automation to update it:
triggers:
- trigger: time_pattern
minutes: 1
minutes: 16
minutes: 31
minutes: 46
conditions:
- condition: time
after: "06:00:00"
before: "22:00:00"
actions:
- action: homeassistant.update_entity
entity_id:
- <your_entity_id_here>
Note: the sensor will still update once when home assistant is restarted so that the sensor is not unknown until the next update time.
pda
3
WOW !
Thank you so much for the clear and detailed answer.
