Hi, anyone could help me to make a config of rest for that output ?
"url": "https://inext.compit.pl/public_api/v1/gates/F9C33ACD5739",
"master": false,
"last_connected_at": "2022-08-12T08:17:41.325295Z",
"devices": [
"version": 5,
"url": "https://inext.compit.pl/public_api/v1/gates/F9C33ACD5739/devices/8156",
"type": 44,
"minor_version": "0",
"last_state": [
"value": 4,
"param_type": "int",
"label": "Wybór schematu pracy regulatora",
"code": "__schematpracy"
"unit": " °C",
"value": 75,
"param_type": "temp",
"label": "Temp zadana zasobnika CWU",
"code": "__tempzadzassol"
"unit": " °C",
"value": 50,
"label": "Temp zadana zasobnika 2 CWU",
"code": "__tempzadzas2cwu"
"unit": " °C",
"value": 35,
"label": "Temp zadana podgrzewacza",
"code": "__tempzadpodgrzprzep"
"unit": " °C",
"value": 35,
"label": "Temp zadana grzałki",
"code": "__tempzadgrz"
"unit": " °C",
"value": 35,
"label": "Temp zadana ładowania CWU z kotła",
"code": "__tempzadladcwuzkotla"
"value_label": "Praca automatyczna",
"value_code": "__automat",
"value": 1,
"param_type": "enum",
"label": "Tryb pracy",
"code": "__trybpracy"
"unit": "°C",
"value": 53.7,
"param_type": "calc",
"label": "Temp kolektora",
"code": "__tkolektora"
"unit": "°C",
"value": 44,
"label": "Czujnik zasobnika dół T2",
"code": "__czujzasobt2"
"unit": "°C",
"value": 49,
"label": "Czujnik zasobnika góra T3",
"code": "__czujzasobt3"
"unit": "°C",
"value": 48,
"label": "Czujnik T4",
"code": "__czujnikt4"
"unit": "kW",
"value": 1,
"label": "Moc kolektora",
"code": "__mockolektora"
"unit": "kWh",
"value": 2.6,
"label": "Energia dzisiaj",
"code": "__endzis"
"unit": "kWh",
"value": 2344,
"label": "Energia zebrana",
"code": "__enzebrana"
"last_connected_at": "2022-08-12T08:17:49.654821Z",
"label": "Regulator solarny",
"id": 8156,
"errors": [],
"class": 18,
"address": 22,
"active": true
"code": "F9C33ACD5739",
"active": true
I want to make sensors to read a parameters like"Temp zadana zasobnika 2 CWU" and other, please give me some example.
How to check that config is working ?
- platform: rest
scan_interval: 900 # Makes a request every 15min
resource: https://inext.compit.pl/public_api/v1/gates/F9C33ACD5739
force_update: true
headers:
Authorization: ***************
