Can anyone shed any light on a set of REST sensors that has worked well until yesterday. They all now report as “unavailable” and looking at the log file is see:
2023-05-11 09:15:59.376 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up rest platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 304, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/rest/sensor.py", line 74, in async_setup_platform
conf[CONF_RESOURCE],
KeyError: 'resource'
I’ve also used CURL from the terminal window and got “curl: (60) SSL certificate problem: unable to get local issuer certificate”.
I can however use a browser & inspect the site which shows the X-MitsContextKey hasn’t changed.
Any suggestions?
Same problem her, it seems to be an issue on Melcloud side. Their own application also stopped working. I assume they are already working on it but I didn’t contact them so you could reach out to their support to be sure.
