REST sensor not showing up under entities
I am experiencing quite an annoying problem. I am trying to add my first REST sensor, and I simply cannot get it to work. My configuration.yaml file looks like this:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
http:
  base_url: ......
  - platform: rest
    resource: http://192.168.1.100:1234/calendar/GetEvents?take=5
If I try to curl the URL, it works fine. Check configuration: All good. Restarted HA: All good.
If I go to Configuration -> Entities, I cannot find it. I can’t find it under Developer Tools -> States either.
I simply cannot find it anywhere. I don’t have a lot of stuff in my Home Assistant environment, so I would easily be able to spot it under another name, but it’s not there.
What have I done wrong?
Works after setting force_update to true. Shrug. I feel like this should be written on the REST page.
  - platform: rest
    force_update: true
Okay, nevermind. After restarting Home Assistant, it’s not working again. What the heck.
Invalid state encountered for entity id: sensor.calendar_events. State max length is 255 characters
This is really, really bad design. How am I supposed to show my calendar events then? I get an array back.
    "name": "Birthday",
    "date": "2020-03-27T15:00:00+01:00"
for example. I need to pass that into my custom lovelace card.
Where did you find that error message? I have no logs or ideas on where to find what is going on.
I have a similar problem.
I added to my configuration.yaml :
# https://www.home-assistant.io/integrations/rest/
  - platform: rest
    resource: https://api-ratp.pierre-grimaud.fr/v3/schedules/bus/120/bry-sur-marne/R?_format=json
    force_update: true
Even though I restarted HA, I cannot find the entity on http://homeassistant.local:8123/config/entities
What did I miss ? :thinking:
I’m also trying to get this to work, tried about everything but doesn’t work.
The entities do not show up, also no errors or any logs around them…
Any luck?
Think I just solved my problem…
Seems you should only have 1 “sensor:” element in configuration.yaml.
If you have multiple of these, your sensors will not show up.
Hope this helps.
