REST sensor not showing up
Hi, I have configured a REST sensor but it is not showing in the list of entities. I have set it up in sensors.yaml
- platform: rest
  resource: http://192.168.1.156/dump1090/data/aircraft.json
  friendly_name: Dump1090
  force_update: true
  value_template: "{{ value_json.messages }}"
  method: GET
  scan_interval: 15
  json_attributes:
    - now
    - aircraft
How do I fix this?
Did you restart Home Assistant after creating it?
Yes I did that a bunch of times
Related errors in your logs?
I dont see any errors related to the REST sensor.
Going to Developer Tools → States you do not see an entity called: sensor.fr24_aircraft?
If not, try removing this and restarting:
it is not a valid configuration option listed here:
I tried, but it still isnt showing up. Very strange this
It’s working now. My config file was a mess, it needed some reformatting
