- resource: "url"
scan_interval: 59
timeout: 300
binary_sensor:
- name: "Regen"
value_template: >-
{% if value_json %}
{{ value_json.Regen }}
{% else %}
None
{% endif %}
I am using this rest template to get data. Sometimes the urls are not available for a short time or the json itself delivers None. In both cases the sensor goes to None and triggers my fail safe scripts.
However, I want the sensor to try again x times before setting the sensor to None. So for example it would retry two times - which means after three minutes the state would go to None if the issue persists. If it has to set a value, it could be the last value as well.
Is this possible in the template?
