Hello!
I have gone through the forum and made my HA able to read data from my Solax inverter via Wi-Fi and rest. Everything works fine but I would like to display days total of PV which Solax itself does not count.
Here is my config:
rest:
- resource: http://<inverter_ip>/optType=ReadRealTimeData
method: POST
headers:
Content-Type: application/json
scan_interval: 5
- name: "Solax PV power"
value_template: "{{ value_json.Data[8] + value_json.Data[9] }}"
unit_of_measurement: 'W'
This works as it should and sums data from PV1 and PV2 but now I need to have another sensor “Solax total PV power” which adds every scan = 5s present value to the previous one and so on. Then I would divide it to have correct number in kWh.
I tried to make separate from the rest and it works but I think it would be better to have only one cycle and that would not work for me
Could you please point me in the right direction?
Thank you very much,
Lukas
