For some reason lately, when Home Assistant first starts up, I get the below error messages in my log file 4 consecutive times ). This causes the value for the respective templates to show as NaN MB/s instead of a value such as 11.03 MB/s.
The below errors in my log happens 4 times in a row when HA first starts up:
2020-09-27 01:00:13 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 264, in _async_template_startup
result_info = async_track_template_result(
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 792, in async_track_template_result
tracker.async_setup()
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 518, in async_setup
self._info[template] = template.async_render_to_info(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 306, in async_render_to_info
render_info._result = self.async_render(variables, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for /: 'NoneType' and 'int
The 4 templates that seem to be causing this issue:
sensors:
horizon_c_drive_read_bytes:
value_template: '{{ ((state_attr("sensor.diskio_0", "read_bytes") / state_attr("sensor.diskio_0", "time_since_update") | int) / 1000000) | round (2) }}'
unit_of_measurement: 'MB/s'
sensors:
horizon_c_drive_write_bytes:
value_template: '{{ ((state_attr("sensor.diskio_0", "write_bytes") / state_attr("sensor.diskio_0", "time_since_update") | int) / 1000000) | round (2) }}'
sensors:
horizon_e_drive_read_bytes:
value_template: '{{ ((state_attr("sensor.diskio_1", "read_bytes") / state_attr("sensor.diskio_1", "time_since_update") | int) / 1000000) | round (2) }}'
sensors:
horizon_e_drive_write_bytes:
value_template: '{{ ((state_attr("sensor.diskio_1", "write_bytes") / state_attr("sensor.diskio_1", "time_since_update") | int) / 1000000) | round (2) }}'
REST sensors that the above templates depend on:
- platform: rest
resource: http://192.168.1.2:61208/api/3/diskio
value_template: '{{ ( value_json[0] ) }}'
json_attributes:
- time_since_update
- disk_name
- read_count
- write_count
- read_bytes
- write_bytes
verify_ssl: false
timeout: 20
scan_interval: 8
- platform: rest
value_template: '{{ ( value_json[1] ) }}'
json_attributes:
- time_since_update
- disk_name
- read_count
- write_count
- read_bytes
- write_bytes
verify_ssl: false
timeout: 20
scan_interval: 8
**Oddly, if I use the same exact 4 templates in Home Assistant’s template editor, the template editor displays the correct values perfectly for each entity. For example, the below template will return correctly values:
will produce:
0.11
However, when the same template is used in my configuration, it will display a NaN value. The state will have a state of, “unknown”.
Hopefully, someone here has an explanation for this. I just puzzled why this started happening recently if I haven’t changed anything in my configuration. I did update Home Assistant a couple of times though. I’m using Home Assistant version 0.115.3
Thank you in advance for your help!
