REST sensor with multiple attributes
You can create a Feature Request (search the category for an existing one first - duplicates will be linked to earlier requests and closed) but be aware that the devs are discouraging the use of attributes where a seperate sensor will do.
I suspect you could make a case for attributes for the template binary sensor as they don’t have an associated device the extra sensor could be attached to.
Funny enough, the template one does seem to support attributes, is the REST one which doesnt
Yes it does. Look at the example:
Edit: oh, restful binary sensor. Ignore that ^
Further to the comments above, I’ve been experimenting with rest sensor but I am unable to get the value_template with multiple attributes to work - I am unable to set the “value_template” to anything other than “OK”, and this is all I can find in the documentation.
Here is my config.yaml entry:
rest:
  - resource: http://my_HP:3000/planets # a VSOP87 planet positions server
    method: GET
    headers:
      User-Agent: Home Assistant
      Accept: application/json
    scan_interval: 300
      - name: "My HP Sun"
        unique_id: phil121
        value_template: "OK"
        json_attributes_path: "$.Sun"
        json_attributes:
            - "RA"
            - "Dec"
            - "Alt"
            - "Az"
            - "Rise"
            - "Set"
      - name: "My HP Mercury"
        unique_id: phil122
        json_attributes_path: "$.Mercury"
        json_attributes:
            - "RA"
            - "Dec"
            - "Alt"
            - "Az"
            - "Rise"
            - "Set"
I had limited success with:
value_template: >
    {{ state_attr('sensor.my_hp_sun', 'alt')|float(0) > 0.0 }}
But it seems I cannot reference an attribute before it is defined, and it always evaluates to false.
Any idea how I can template a useful value_template for a rest sensor?
I found the answer in another post. In case anyone wonders, you must reference the json rather than state_attr:
rest:
  - resource: http://my_hp:3000/planets # a VSOP87 planet positions server
    method: GET
    headers:
    scan_interval: 300
      - name: "Phil-HP Sun"
        unique_id: phil121
        value_template: "{{ value_json['Sun']['Alt']|float(0) > 0.0 }}"
        json_attributes:
            - "RA"
            - "Dec"
            - "Alt"
            - "Az"
            - "Rise"
            - "Set"
… much more useful than “OK” for the state of the sensor.
