REST sensors stopped to work after update to 2024.8
After changes in how the weather works in HA now, I completely dropped integration for my own set of REST sensors working with Weatherbit. Everything worked fine until update to 2024.8. After upgrade, for every sensor I created I get in log file error message (posting just example for one sensor, all looks the same):
2024-08-08 20:57:14.664 ERROR (MainThread) [homeassistant.components.sensor] Error adding entity sensor.condition_0 for domain sensor with platform rest
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 598, in _async_add_entities
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 912, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1365, in add_to_platform_finish
    await self.async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/helpers/trigger_template_entity.py", line 162, in async_added_to_hass
    await super().async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/rest/entity.py", line 43, in async_added_to_hass
    self._update_from_rest_data()
  File "/usr/src/homeassistant/homeassistant/components/rest/sensor.py", line 187, in _update_from_rest_data
    self._process_manual_data(raw_value)
  File "/usr/src/homeassistant/homeassistant/helpers/trigger_template_entity.py", line 250, in _process_manual_data
    self._render_templates(variables)
  File "/usr/src/homeassistant/homeassistant/helpers/trigger_template_entity.py", line 190, in _render_templates
    rendered[key] = self._config[key].async_render(
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 597, in async_render
    compiled = self._compiled or self._ensure_compiled(limited, strict, log_fn)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 798, in _ensure_compiled
    assert self.hass is not None, "hass variable not set on template"
AssertionError: hass variable not set on template
Sensor are visible in Developer Tools → States, but only holds some old value as state, with no attributes created.
Here is the code for the sensor resulting in error above:
rest:
- resource: http://192.168.52.53:8123/local/weatherbit_forecast.json
    - name: condition_0
      value_template: "{{ value_json.data[0].weather.description }}"
      icon: >
        {% set condition = value_json.data[0].weather.code %}
        {% if condition == 200 %} mdi:weather-partly-lightning
        {% elif condition == 201 %} mdi:weather-partly-lightning
        {% elif condition == 202 %} mdi:weather-partly-lightning
        {% elif condition == 203 %} mdi:weather-partly-lightning
        {% elif condition == 230 %} mdi:weather-lightning
        {% elif condition == 231 %} mdi:weather-lightning-rainy
        {% elif condition == 232 %} mdi:weather-lightning-rainy
        {% elif condition == 233 %} mdi:weather-lightning-rainy
        {% elif condition == 300 %} mdi:weather-rainy
        {% elif condition == 301 %} mdi:weather-rainy
        {% elif condition == 302 %} mdi:weather-rainy
        {% elif condition == 500 %} mdi:weather-pouring
        {% elif condition == 501 %} mdi:weather-pouring
        {% elif condition == 502 %} mdi:weather-pouring
        {% elif condition == 511 %} mdi:weather-pouring
        {% elif condition == 520 %} mdi:weather-pouring
        {% elif condition == 521 %} mdi:weather-partly-rainy
        {% elif condition == 522 %} mdi:weather-pouring
        {% elif condition == 600 %} mdi:weather-partly-snowy
        {% elif condition == 601 %} mdi:weather-snowy
        {% elif condition == 602 %} mdi:weather-snowy-heavy
        {% elif condition == 610 %} mdi:weather-partly-snowy-rainy
        {% elif condition == 611 %} mdi:weather-snowy-rainy
        {% elif condition == 612 %} mdi:weather-snowy-rainy
        {% elif condition == 621 %} mdi:weather-partly-snowy
        {% elif condition == 622 %} mdi:weather-snowy-heavy
        {% elif condition == 623 %} mdi:weather-snowy
        {% elif condition == 700 %} mdi:weather-hazy
        {% elif condition == 711 %} mdi:weather-hazy
        {% elif condition == 721 %} mdi:weather-hazy
        {% elif condition == 731 %} mdi:weather-dust
        {% elif condition == 741 %} mdi:weather-fog
        {% elif condition == 751 %} mdi:weather-hazy
        {% elif condition == 800 %} mdi:weather-sunny
        {% elif condition == 801 %} mdi:weather-partly-cloudy
        {% elif condition == 802 %} mdi:weather-partly-cloudy
        {% elif condition == 803 %} mdi:weather-partly-cloudy
        {% elif condition == 804 %} mdi:weather-cloudy
        {% else %} mdi:cloud-question-outline
        {% endif %}
Source (intermediate step) JSON file is created properly and contains all necessary data. Here is sample with needed nodes:
   "city_name":"Zielonka",
   "country_code":"PL",
   "data":[
         "app_max_temp":24.5,
         "app_min_temp":17.5,
         "clouds":46,
         "clouds_hi":44,
         "clouds_low":50,
         "clouds_mid":35,
         "datetime":"2024-08-09",
         "dewpt":14.8,
         "high_temp":24.7,
         "low_temp":17.3,
         "max_dhi":null,
         "max_temp":24.7,
         "min_temp":17.5,
         "moon_phase":0.33,
         "moon_phase_lunation":0.19,
         "moonrise_ts":1723192128,
         "moonset_ts":1723233117,
         "ozone":322,
         "popp":40,
         "precip":1.8959961,
         "pres":1004,
         "rh":73,
         "slp":1015,
         "snow":0,
         "snow_depth":0,
         "sunrise_ts":1723172933,
         "sunset_ts":1723227058,
         "temp":20.4,
         "ts":1723154460,
         "uv":7,
         "valid_date":"2024-08-09",
         "vis":24,
         "weather":{
            "icon":"r01d",
            "description":"Light rain",
            "code":500
         "wind_cdir":"W",
         "wind_cdir_full":"west",
         "wind_dir":276,
         "wind_gust_spd":5.2,
         "wind_spd":2
What is wrong here? Frankly speaking this error message gives me no clue what is not right…
OK, I made some more investigations and it looks that REST sensor stopped to accept templates for icon:
  • If I remove the icon section entirely everything works fine.
  • If I replace it with hardcoded icon name everything works fine.
  • If I move the icon template to value_template it works fine (as state, obviously, not attribute), so my template is working OK (and it was prior to 2024.8).
Conclusion; something wrong with templating icon in REST sensor… at least for me. Does anybody else face such issue? Or do you have any examples of REST sensor with templated icon that works after update to 2024.8?
That looks like a bug. Open an issue.
Just did it and already received response - seems that was a bug and will be fixed in 2024.8.1
