TL;DR: I think there’s a lot to be gained if we could define sensors in REST integration just like defining sensors in Template integration, benefits include ability to map values, ability to do basic transformation and enumeration.
Well in my case, here’s my use case, sorry for verbosity, I don’t know how to make it any shorter but keep the clarity.
Data and Current Configuration
To give some context, I have a RESTful integration that polls an API with the following response:
"BusStopCode": "20251",
"Services": [
"ServiceNo": "176",
"Operator": "MY_BUS_OPERATOR",
"NextBus": {
"OriginCode": "10009",
"DestinationCode": "45009",
"EstimatedArrival": "2020-02-12T14:09:11+08:00",
"Latitude": "SOME_COORDINATE",
"Longitude": "SOME_COORDINATE",
"VisitNumber": "1",
"Load": "SEA",
"Feature": "WAB",
"Type": "DD"
"NextBus2": {
"EstimatedArrival": "2020-02-12T14:21:19+08:00",
"VisitNumber": "1",
"Load": "SEA",
"Feature": "WAB",
"Type": "DD"
"NextBus3": {
"EstimatedArrival": "2020-02-12T14:44:30+08:00",
"VisitNumber": "1",
"Load": "SEA",
"Feature": "WAB",
"Type": "DD"
...otherServices // Right now limited to 1 since I don't know how to dynamically create sensors.
So then, I have sensors for each “NextBus” instance (each bus service only returns up to 3 next bus instances), exposing every json data inside each json object. For brevity, I only included one ‘next bus’ from my instance, the other two are pretty much the same as the one defined below.
resource: MY_3RD_PARTY_RESOURCE_URL
- name: "REST: My Next Bus"
value_template: "{{ value_json.Services[0].NextBus.EstimatedArrival }}"
device_class: timestamp
json_attributes_path: "$.Services[0].NextBus"
json_attributes:
- OriginCode # Basically all the attributes inside each next bus instance.
- DestinationCode
- EstimatedArrival
- Latitude
- Longitude
- VisitNumber
- Load
- Feature
- Type
Here is a list of items I feel could be improved on:
Inconvenience 1:
Mapping properties from JSON to attribute
The GPS coordinates of the bus are listed in the JSON object as Latitude
and Longitude
. When adding those to the attribute, the map ignores the coordinates and does not display the entities on the map.
I have to create another template sensor which maps Latitude
and Longitude
to latitude
and longitude
(yes just making the names lower case
) for it to show up.
Inconvenience 2:
Template string based sensor name
The bus services also end at about 1am daily (depending on traffic).
Afterwhich, the data of each field becomes an empty string.
Eg: "{{ value_json.Services[0].NextBus.EstimatedArrival }}"
Instead of an ISO8601 datetime string, if bus service ended, it will return: ''
When this is the case, I want to name (friendly name) the sensor as {{ Bus Service Number }} - Service Ended
This is also only possible right now with template sensors.
Inconvenience 3:
Template string based attributes and basic data transformation
The data provided by the API is extremely abbreviated and does not make sense to be used immediately.
For example:
// This means 'SEAting is available'
"Load": "SEA", // Seats Available (SEA), Standing Available (SDA), Limited Standing (LDA)
"Feature": "WAB", // Wheelchair Accessible Bus
"Type": "DD" // Double Deck (DD), Single Deck (SD), Bendy Bus (BD)
It would be great to have just a template built right in to parse these enumerated values into something that’s human readable.
Inconvenience 4:
Template string based sensor icon
Same for icons, would be nice to set an icon template to RESTful sensors by enumerating a property on value_json using template strings.
From the above examples, I am show the type of bus using the icon (double deck / single deck), and bus with alert icon when the service has ended. This is already possible using a second template sensor, but not possible directly from RESTful sensor.
Inconvenience 5:
Config block based unique_id
I couldn’t seem to set a unique_id
directly from the RESTful sensors. Would be nice if we could do block configuration for that just like in template sensors (the non-legacy way).
For example, I would name the entire block with {bus stop code}_{bus service number}
, then each sensor would only need to append next_bus
, next_bus_2
, next_bus_3
Conclusion
If you’re still here, thank you for reading this.
The above points are why I think it would be nice to integrate how things are done in the Template integration today with the RESTful integration.
I’m sure others have faced the same situation while using other APIs that are out of their control, and thought this is a pretty generic use case that can benefit the length of everybody’s entity list. ![:joy: :joy:](https://community.home-assistant.io/images/emoji/twitter/joy.png?v=12)
All the cases above can be solved today with Template integration, just would be nice to not have 2 entities for each bus.
