I have an Android tablet running the companion app, and I want to use it for a wallpanel. To save battery, I want to turn the screen off at night.
I’ve found this post in Reddit (https://www.reddit.com/r/homeassistant/comments/1app4vn/turn_onoff_tablet_using_companion_app/) that explains how to do it by enabling/disabling the ‘Always keep screen on’ option. It also uses command_launch_app
to restar the companion app (so it picks the new config for the screen). And that last part is not working for me.
The command I’m using is
- service: notify.mobile_app_wallboard_entrada
message: command_launch_app
package_name: io.homeassistant.companion.android
enabled: true
The command seems to be correct. When looking at the companion app logs, I do see the command being processed.
The package name seems to be correct as well. I’ve found that any other package name (like adding .full
or .minimal
at the end) results in a dialog saying the package can’t be found. That specific string (“io.homeassistant.companion.android”) doesn’t trigger that error and matches the ID used by the companion app.
However, the app is not restarted. If I have open a submenu in the UI, it stays open forever (I’d assume than an app restart will close the submenu). As such, the setting for enabling/disabling the option to keep the screen always on doesn’t seem to work.
Why the app is not restarting? Am I missing something?
