I just restarted my HASS on 0.33.4 and it worked. Although it feels like a hit or miss, it works most times but sometimes it just stops and I need to stop and start it from systemd. System uptime is over 50 days so that is not something I have needed do yet.
stopping via systemd does stop HASS but some child services keep running like the hbmqtt… and than starting hass via systemd makes a mess as mqtt devices still connected to the old instance… at least that is how it looks from my perspective…
There have been a number of issues reported with this on github in the past and I think it may be hard to squash the bugs on each system configuration and option. When there was an issues in a earlier release I created a script which seems to work every time even though it is calling the same service.
restart_home_assistant:
alias: Restart Home Assistant
sequence:
service: homeassistant.restart
Scripts work nicely for this as you can add additional commands (call a shell command) if you want to stop other items/services before you call the restart command.
