Restart HASS if Hue not detected
I want to take the “Restart Home Assistant if Wemo is not detected” example from the website and convert it to restart if my Hue lights/bridge is not detected, what do I need to change in the example code?
mqtt:
  broker: 127.0.0.1
  port: 1883
  client_id: home-assistant-1
  keepalive: 60
device_tracker:
  - platform: nmap_tracker
    hosts: 192.168.0.1-255
    home_interval: 1
    interval_seconds: 30
    consider_home: 900
ifttt:
  key: ***
notify:
  - platform: pushbullet
    api_key: ***
switch:
  - platform: wemo
  - platform: mqtt
    state_topic: "home/killhass"
    command_topic: "home/killhass"
    qos: 0
    payload_on: "ON"
    payload_of: "OFF"
    optimistic: false
script:
  restarthawemo:
    alias: "Restart HA if WeMo isn't found after 15 minutes"
    sequence:
      - delay:
          minutes: 15
      - service: notify.pushbullet
          message: 'WeMo not found, restarting HA'
      - service: switch.turn_on
          entity_id: switch.killhass
automation:
- alias: "Restart HA if WeMo switch isn't found after 15 minutes"
    platform: state
    entity_id: device_tracker.wemo
    to: 'home'
  condition:
    - condition: template
      value_template: '{% if states.switch.wemo %}false{% else %}true{% endif %}'
    - condition: state
      entity_id: script.restarthawemo
      state: 'off'
    service: homeassistant.turn_on
- alias: 'Stop HA'
    - platform: state
      entity_id: switch.KillHass
      state: 'on'
    service: homeassistant.stop
  - alias: 'Stop restarting HA is WeMo is found'
    platform: template
    value_template: '{% if states.switch.wemo %}true{% else %}false{% endif %}'
  condition:
    condition: state
    state: 'on'
    service: homeassistant.turn_off
