Klagio
(Klagio)
August 23, 2019, 10:02am
1
Sometimes my HASS get stuck (I know should go into the cause of it, but for now haven’t solved yet) and I need to restart it.
Currently I solve the issue by accessing with my Android phone with SSH into HASSIO host and do the command “sudo docker restart homeassistant”.
I wish to achieve the above command more easily, like pressing a button on my phone (when its stuck, the browser does not show the frontend), like with HTTP SHORTCUT, which sends a URL POST command for restarting the docker,
is it possible, which would be the URL?? Or other ways?
Do automations and stuff still run? Or is everything locked up?
You could install the portainer aaddon if it’s hass.io and access that to restart the container
I restart Ha with Telegram, he execute a Script with a service.homeassistant_restart
Abertil
(Andreas Jonasson)
August 23, 2019, 11:07am
4
I’m doing this through webhooks.
- alias: 'Webhook: Restart HA'
initial_state: true
hide_entity: false
platform: webhook
webhook_id: ha_restart
- service: homeassistant.restart
- alias: 'Webhook: Restart HA server'
initial_state: true
hide_entity: false
platform: webhook
webhook_id: ha_restart_server
- service: hassio.host_reboot
Using Nabu Casa webhooks. But with that said, if your HA really hangs this won’t work, then the automations won’t run anyway.
Klagio
(Klagio)
August 23, 2019, 11:42am
5
Sometimes things run sometimes not.
I need a fast solution for my phone, (with a simple press of a button) so accessing portainer is not a good option for me, I have a solution already (accessing with SSH)
Klagio
(Klagio)
August 23, 2019, 11:43am
6
May I see you code? Thanks
Klagio
(Klagio)
August 23, 2019, 11:45am
7
for the moment I found that works with a POST URL as
https://xxx.duckdns.org/api/services/homeassistant/restart?api_password=xxx
like this it restart homeassistant, but not the docker (?), anyone knows what that means in different behaviour (do not understand much about docker)
Klagio
(Klagio)
August 23, 2019, 12:03pm
8
Actually no, just now it got stuck, I did the restart as per the POST URL, and did not work (it worked before), so I had to do a sudo docker restart homeassistant, and it worked
So I need a way to give easily the
or equivalent
nickrout
(Nick Rout)
August 23, 2019, 10:01pm
9
So this is a docker question. Does it have a rest api?
This should give you some docker features exposed to Home Assistant to do things like restarting a docker container. I haven’t used it, but, I’ve seen it mentioned quite a few times in these forums.
Klagio
(Klagio)
August 24, 2019, 7:26am
11
Yep that should do, thanks a lot.
I installed it, it is running, as per instruction I did
http://192.168.1.10:8126/container/home-assistant
and the result is
container not found
When I use PORTAINER HASSIO addon I see two containers
ha-dockermon
and
hassio_dns
Can anyone guide me a bit, since I am not good in docker and linux in general
Klagio
(Klagio)
August 24, 2019, 7:39am
12
when I do docker ps I receive
io@ubuntu:~$ sudo docker ps
[sudo] password for io:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
5c80634084dc hassioaddons/portainer-amd64:0.7.4 "/init" 21 minutes ago Up 21 minutes addon_a0d7b954_portainer
e669b418dd18 esphome/esphome-hassio-amd64:1.13.6 "/init" 13 hours ago Up 13 hours addon_15ef4d2f_esphome
ff14c8ae157f hassioaddons/appdaemon3-amd64:4.0.2 "/init" 13 hours ago Up 13 hours 0.0.0.0:5000->5000/tcp, 0.0 .0.0:5665->5050/tcp addon_a0d7b954_appdaemon3
2961c30ac74b hassioaddons/nginxproxymanager-amd64:0.2.1 "/init" 13 hours ago Up 13 hours 0.0.0.0:80-81->80-81/tcp, 0 .0.0.0:443->443/tcp addon_a0d7b954_nginxproxymanager
cd4fe155b635 homeassistant/qemux86-64-homeassistant:0.97.2 "/bin/entry. sh pytho…" 13 hours ago Up 13 hours homeassistant
c7e306723daa homeassistant/amd64-addon-samba:8.1 "/run.sh" 13 hours ago Up 13 hours addon_core_samba
4c795adf8e12 homeassistant/amd64-addon-ssh:6.3 "/run.sh" 13 hours ago Up 13 hours 0.0.0.0:23->22/tcp addon_core_ssh
1852a7ebe1fa homeassistant/amd64-addon-duckdns:1.9 "/run.sh" 13 hours ago Up 13 hours addon_core_duckdns
8a708f9ec5e9 samccauley/amd64-googlebackup:1.6.2 "/run.sh" 13 hours ago Up 13 hours 0.0.0.0:8055->8000/tcp addon_3833edd4_googlebackup
4efe7f1beed9 hassioaddons/tor-amd64:2.0.0 "/init" 13 hours ago Up 13 hours 0.0.0.0:9050->9050/tcp addon_a0d7b954_tor
4a37f98cf0d5 hassioaddons/vscode-amd64:0.6.4 "/init" 13 hours ago Up 13 hours addon_a0d7b954_vscode
2a6be897d354 hassioaddons/zerotier-amd64:0.4.1 "/init" 13 hours ago Up 13 hours addon_a0d7b954_zerotier
8d2eb90b614d homeassistant/amd64-addon-rpc_shutdown:1.0 "/run.sh" 13 hours ago Up 13 hours addon_core_rpc_shutdown
15c35087471f 89275b70/amd64-addon-dss_voip:1.1.0 "/init /run. sh" 13 hours ago Up 13 hours addon_89275b70_dss_voip
3866c46e9233 hassioaddons/traccar-amd64:0.5.2 "/init" 13 hours ago Up 13 hours addon_a0d7b954_traccar
921dbb3847bb hassioaddons/glances-amd64:0.5.3 "/init" 13 hours ago Up 13 hours addon_a0d7b954_glances
9e19927fcdd3 hassioaddons/sonweb-amd64:0.8.1 "/init" 13 hours ago Up 13 hours 0.0.0.0:9541->9541/tcp addon_a0d7b954_sonweb
0018b64cedc1 homeassistant/amd64-addon-mosquitto:5.0 "/run.sh" 13 hours ago Up 13 hours 0.0.0.0:1883-1884->1883-188 4/tcp, 0.0.0.0:8883-8884->8883-8884/tcp addon_core_mosquitto
136ca6ac0a72 hassioaddons/chrony-amd64:1.0.3 "/init" 13 hours ago Up 13 hours 0.0.0.0:123->123/udp addon_a0d7b954_chrony
1ffe48eb2887 hassioaddons/pi-hole-amd64:3.0.2 "/init" 13 hours ago Up 13 hours addon_a0d7b954_pi-hole
6bf2b82cee80 homeassistant/amd64-addon-dhcp_server:1.2 "/run.sh" 13 hours ago Up 13 hours addon_core_dhcp_server
e4641759712b bestlibre/amd64-syncthing:1.1.0 "/run.sh" 13 hours ago Up 13 hours 0.0.0.0:8384->8384/tcp, 0.0 .0.0:21027->21027/udp addon_53caca22_syncthing
dcf73cae249c homeassistant/amd64-hassio-dns:1 "coredns -co nf /conf…" 13 hours ago Up 13 hours hassio_dns
ee8da7615eff homeassistant/amd64-hassio-supervisor "/bin/entry. sh pytho…" 16 hours ago Up 13 hours hassio_supervisor
5081766211e7 philhawthorne/ha-dockermon "/bin/sh -c 'npm sta…" 3 months ago Up 13 hours 0.0.0.0:8126->8126/tcp ha-dockermon
Klagio
(Klagio)
August 24, 2019, 7:51am
13
Sorry for the late answer, I am currently very busy at work
AUTOMATION:
- id: Telegram - Antworten
alias: 'Telegram Inline Keyboard'
initial_state: 'on'
hide_entity: false
platform: event
event_type: telegram_command
event_data:
command: '/start'
- service: notify.telegram_homeassistant
message: 'Verfügbare Informationen von Home-Assistant Server'
keyboard:
- '/Temperaturen, /Drucker'
- '/Heizung, /Steuerung'
- '/Kamera, /Snapshots, /Videos'
- id: Telegram - Inline Keyboard
alias: 'Telegram Control Pannel Command'
initial_state: 'on'
platform: event
event_data:
command: '/Steuerung'
message: >
"Home Assistant Status",
"Control Panel",
"Yes Sir!",
"Home Assistant Control Panel",
] | random }}
inline_keyboard:
- 'System:/system'
- 'And more:/more'
- alias: 'Telegram - System Aktionen'
initial_state: 'on'
hide_entity: true
platform: event
event_type: telegram_callback
event_data:
data: '/system'
- service: telegram_bot.answer_callback_query
data_template:
callback_query_id: '{{ trigger.event.data.id }}'
message: 'Was willst du Ausführen in Home-Assistant?'
- service: telegram_bot.send_message
data_template:
title: 'Home-Assistant System Aktionen'
target: <chat_ID>
message: 'Anscheinend möchtest du etwas auf deinen Home-Assistant Server unternehmen! Was willst du tun?'
inline_keyboard:
- "Home-Assistant Neustart:/restart"
- 'And more:/more'
SCRIPT:
restart_ha:
alias: Restart HomeAssistant
sequence:
- data: {}
Have fun! I have a proper menu structure, so several automations are necessary for me.
Regards
Is your HA is exposed using opening a port or Nabu Casa?
If using Nabu Casa what is setup required in HA+Nabu Casa please?
