I’ve noticed that my google nest integration is not polling correctly from the API. On further investigation I notice that this is a known issue. It gets fixed by reloading the integration. Is there a way to automate this restart if the logbook entry on an entity from the integration is not updated in X minutes or hours?
I have been able to solve this through a bit of trial and error.
Step 1) Create a helper that records the time that the entity was last updated. Helper Type ‘Date and/or Time’ then make sure input type ‘Date and Time’ is selected.
Step 2) create automation that updates the helper created in step 1
Use below Yaml for the automation code
alias: Update Nest Last Updated Helper
description: “”
triggers:
- entity_id: [entity id of one of your nest thermostats it will start climate. ]
trigger: state
actions: - target:
entity_id: [entity if of the helper you just created it will start input_datetime. ]
datetime: “{{ now().isoformat() }}”
action: input_datetime.set_datetime
mode: single
Step 3: creat automation to resart nest automation
Use the below Yaml which will check your helper every 5 mins to see if it is over 1 hour old
alias: Reload Nest Integration if No Update in 1 Hour
description: “”
triggers:
- minutes: /5
trigger: time_pattern
conditions: - condition: template
value_template: >
{% set last = states(‘input_datetime.XXX [from step 1]’) %} {% if
last in [‘unknown’, ‘unavailable’, None] %}
false
{% else %}
{% set last_dt = strptime(last, ‘%Y-%m-%d %H:%M:%S’) %}
{{ (now().replace(tzinfo=None) - last_dt).total_seconds() > 3600 }}
{% endif %}
actions: - action: homeassistant.reload_config_entry
entry_id: YYY [you can find this be navigating to Settings-Devices and Services-Google Nest under integration entries click the three dots next to the entry you want to restart click download diagnostics. The entry_id will be the string of numbers and letters just before .json at the end of the file name.
mode: single
