Restart not working (even with version of Sept 2020)
Hi
The option restart under server management never worked for me. (the one which appears under -> Configuration-> server controls -> server management.
My installation is running on DS918+ with the latest DSM update.
is this a known issue?
thank and regards
If that doesn’t work it typically means you have a config check error.
Check your log file and the results of both the UI and command line config checkers.
