Restart required notification
Hi
How do I trigger a notification/ automation when a Restart is required?
My HA is running smooth and I automatic update my add-on, ESPhome devises and as much as I can.
I know this is not popular :smiley:, but for automation to work, I don’t want to do a lot of admin work to reading release notes, doing updates and restarts.
Thomas
HOMEASSISTANT_START, HOMEASSISTANT_STARTED
These events are fired during the startup of Home Assistant, in the following order:
  1. homeassistant_start
  2. homeassistant_started
These events contain no additional data.
If you want to trigger automation on a Home Assistant start event, we recommend using the special Home Assistant trigger instead of listening to these events.
I like to trigger when this happens
Make a binary sensor template using this code
  states.update |
  selectattr('attributes.release_summary','eq','<ha-alert alert-type=\'error\'>Restart of Home Assistant required</ha-alert>') |
  list | count
and use that turning on as a trigger or condition :slight_smile:
here’s my automation
alias: Restart Home Assistant
description: ""
  - platform: time
    at: "00:15:00"
condition:
  - condition: state
    entity_id: binary_sensor.restart_required
    state: "on"
  - service: homeassistant.restart
    data: {}
mode: single
