When I make changes to my configuration, restarting the Home Assistant server ensures that the changes are applied.
However, in the last few days I have been looking for the reason why a small change (adding some entities to saving in Influxdb) was not processed. When I restarted the Docker container today, it worked. took me a few hours: unamused:
The same thing happened once before when I wanted to add an IP camera while some others were displayed correctly.
If someone recognizes this, can you tell me when I just need to restart the home assistant server and when I have to restart the container?
Thatâs not possible. I assume you mean you are running Home Assistant in Docker. Hassbian is a pi-only distribution, based on Raspbian, which is a pi only distribution.
The best thing to do is always restart the container. Using the restart button in HA is iffy at best.
It is annoying that the restart button / service doesnât work reliably. I hate to just arbitraritly kill the running process for fear of corrupting an sqlite3 database update or something. Itâs not obvious how many worker threads are still running (or ideally, what theyâre suspended onâŚ) after punching the restart button and just waiting⌠awhile⌠before giving up and restarting the Docker container.
I run Home Assistant on Ubuntu 18.04 as the distributed Docker image.
You could set your HA Docker container restart policy to âAlwaysâ then when you select server stop in HA itâll restart the docker container automatically (and I assume will have shut down gracefully).
JS1, are you able to provide some simple instructions on how one might go about that?
Iâm running lubuntu and am currently having a strange problem where, after boot, docker will start with homeassistant container running, but home assistant wonât be accessible. To make it accessible, I do a sudo docker restart homeassistant, restarting the docker container. Then Home Assistant boots properly and comes online.
Similarly, if I restart Home Assistant from inside home assistant (webgui), it doesnât come back on by itself. Again, I have to manually restart the docker container.
I find it quite weird as I havenât really messed around with docker since my install of home assistant quite a while ago. Could it have been affected by some update?
Hi, sorry for the late reply, I missed the notification that there was a new post.
In fact I manage my Docker containers with Portainer which makes it super easy to update HA and very easy to change the restart policy for a container, there is a field called restart policies, you select the one you want and click update.
Portainer made me a bit lazy with Docker to be honest, I stared off controlling Docker with the CLI but havenât looked back since using Portainer.
Did you find a solution for this? I have been facing the exact same problem for a while. Also running the official container image, on RPi in my case. Restarting HA from the web UI will make it stop working however it never comes back up. HA then requires a docker-compose restart from CLI to come back to life, itâs annoying. Running the current stable image as of today.
The logs show nothing - itâs like the shutdown gets stuck, because I see the log is not re-initialized until the docker-compose restart is done
I have docker on a Synology Nas. Restarting the container is very easy. I donât use compose. When restarting from the web doesnât give the expected result I restart the container.
Hi, Did you find a solution to this please as i have exactly the same behaviour? Restart in the UI often only stops HA but it doesnât come back up and iI then need to restart the container
