Restart\Shutdown in Hardware tab missing
In Settings - System - Hardware tab there used to be a Restart - Shutdown host? Did it move again? If so can someone show me where it went or does everyone have this issue? I am running core-2022.6.1. I had the same issue on core-2022.6.0 and it was there in core-2022.5.5.
Thanks, Ed.
You have the right location. It’s under the three dot icon (“meatball icon”) top right of that page.
Thank you. It was better located where you could see them before next to your system.
Actually, I really like the new layout and I hope they change it back. It’s just hard to find things and adding another menu item is not the way to go. It just made since where they had it.
I looked for the shutdown option for 5 min, could not find it. Finally I stumbled upon this post and then I managed to locate it. Thank you!
If the devs ever read this, this option should not be so hidden. There should be buttons for restart and shut down on the hardware setting page itself, not only under the dots menu.
Reasonably sure it was done on purpose. A lot of people don’t know the difference between restart and reboot.
Also this menu page is a work in progress.
Tricked me also - I lost the menu options after upgrade. I sort of agree with Un4Seen that this is way too hidden. Might have been searching the whole night if it wasn’t for this post.
Thanks! :heart:
