Restart Z-Wave Config from Scratch
So I am at a loss to explain what happened since 0.83 but my Z-Wave is a mess and I can’t seem to fix it…so with regret…
How do I wipe out my entire Z-Wave configuration including all the entity registries and start again - when I tried removing a device - it worked but did not affect the entity registry.
So I do a controlled removal of as many devices as possible from the Z-Wave network
I reset the Aeon Stick
I remove the Z-wave configuration including the stick and bring up HA and confirm all the tries are gone (still had the entity registry stuff when I did this as a test)
Once all the old stuff is gone - still not sure how I do this…I bring up a clean Z-Wave environment
The more I wire this the more I feel I should just delete the whole HA configuration and start again from scratch and re-add bits of config as I go.
Thoughts pls?
I have the same issue and would love to start over again…
Anyone?
Anyone ever document how to do this?
