I had my raspberry pi 3+ working for sometime and something happened so I decided to start from scratch as I could not access it any longer.
The problem I’m having is with duckdns. I already had an account so I put in the token and domain that duckdns gives me which is the same as the one I had prior. The log below shows it’s working but I get an unable to connect to Home Assistant error when I try to go to https://xxxx.duckdns.org:8123 or xxxx.duckdns.org
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “xxxx”,
“domains”: [
“xxx.duckdns.org”
“seconds”: 300
INFO: Using main config file /data/workdir/config
- Account already registered!
[19:16:40] INFO: OK
192.0.xxx.xx
NOCHANGE
Processing xxxx.duckdns.org
- Checking domain name(s) of existing cert… unchanged.
- Checking expire date of existing cert…
- Valid till Feb 6 15:02:46 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[19:21:46] INFO: OK
192.0.xxx.xx
NOCHANGE
[19:26:46] INFO: OK
192.0.xxx.xx
NOCHANGE
