Restarts docker instance every ~10 minutes?
So… starting with 0.80.0 my hass.io instance have been starting to restart the docker container every 10 minutes? Tried reinstalling, different sd cards, disabling different addons etc.
Supervisor log:
18-10-15 17:52:15 ERROR (MainThread) [hassio.homeassistant] Can't update Home Assistant access token!
18-10-15 17:52:15 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!
18-10-15 17:52:15 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 17:52:49 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 17:52:51 INFO (SyncWorker_15) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.80.0
18-10-15 17:55:54 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
i have the same problem… and sometime the web ui it doesn’t load so i have to restart manually.
I have the same problem, and the service I installed from mqtt is all the time disconnecting and connecting.
For me the problem was that home-assistant had blocked it’s own internal IP… o.0
If you have ip ban on check that, mine is working fine now!
