freshfitz
(Ryan Fitz)
August 6, 2023, 11:59am
1
I have tried a ton of configs and can not get multiple values in my tile, what is the right format?
configuration.yaml I have
sensor: !include sensor.yaml
sensor.yaml
- platform: rest
resource: http://10.0.0.31
unique_id: oil_sensor
value_template: "{{ value_json.gals}} "
unit_of_measurement: gals
name: Oil Sensor percentage
value_template: "{{ value_json.percentage}} "
unit_of_measurement: percentage
My stats just pull percentage, I want both percentage and gals
json
{“in”: 10.141732283464567, “name”: “OilSensor”, “cm”: 25.76, “gals”: 230.91622745745494, “percentage”: 92.36649098298197}
freshfitz
(Ryan Fitz)
August 6, 2023, 12:04pm
2
I can do this but then I need to add 2 cards to my dashboard 1 for ea variable
- platform: rest
- platform: rest
unique_id: oil_sensor2
koying
(Chris B)
August 6, 2023, 12:56pm
3
You have to use the rest integration, not the platform
# Example configuration.yaml entry
rest:
- resource: "https://api.openweathermap.org/data/2.5/weather?zip=80302,us&APPID=VERYSECRETAPIKEY"
- name: "Report"
value_template: "{{ value_json['weather'][0]['description'].title() }}"
picture: "{{ 'https://openweathermap.org/img/w/' + value_json['weather'][0]['icon'].lower() + '.png' }}"
- name: "Outside temp"
value_template: "{{ value_json['main']['temp'] - 273.15 }}"
unit_of_measurement: "°C"
- name: "Outside pressure"
value_template: "{{ value_json['main']['pressure'] }}"
unit_of_measurement: "hP"
- name: "Outside humidity"
value_template: "{{ value_json['main']['humidity'] }}"
unit_of_measurement: "%"
freshfitz
(Ryan Fitz)
August 6, 2023, 3:30pm
4
Oh so it has to go into the configuration.yaml then?
rossk
August 6, 2023, 4:08pm
5
Yes OR use an include rest.yaml and put it in there.
freshfitz
(Ryan Fitz)
August 7, 2023, 12:21am
6
Thanks koying, that worked
