hkapanen
(Harri Kapanen)
November 14, 2019, 6:58pm
1
I’m trying to post a simple http command to a device with a RASTful command but fail to get the variables through to url;
rest_command:
set_garo_timer:
url: http://192.168.0.230:80/v1/timer/{{ id }}
method: POST
payload: 'test'
verify_ssl: false
When calling this from dev tools services with {id:"0"}
as data, I get in log:
Error 404 on call http://192.168.0.230:80/v1/timer/.
Also, the payload does not seem to appear there.
Any Advice, please?
Oh, this is with Hassio 0.101.3.
SteveDinn
(Steve Dinn)
November 14, 2019, 11:15pm
2
That’s an easy one: You can’t use templates in the services dev tools.
SteveDinn
(Steve Dinn)
November 14, 2019, 11:23pm
3
Wait. I think I misunderstood. This should work. I actually do something very similar. Can you screenshot your dev services page?
hkapanen
(Harri Kapanen)
November 15, 2019, 7:24am
4
Sure, here you go:
The code in configuration.yaml:
rest_command:
test_call:
url: "http://192.168.0.230:80/v1/timer/{{ id }}"
method: POST
payload: 'Testing it'
verify_ssl: false
And the corresponding line in the log:
2019-11-15 09:17:44 WARNING (MainThread) [homeassistant.components.rest_command] Error 404 on call http://192.168.0.230:80/v1/timer/.
I’d expect the log to have
http://192.168.0.230:80/v1/timer/0
SteveDinn
(Steve Dinn)
November 15, 2019, 12:35pm
5
I have a very similar rest_command:
rest_command:
slack_api:
url: https://slack.com/api/{{ api }}
content_type: 'application/json; charset=utf-8'
verify_ssl: true
method: 'post'
timeout: 20
headers:
Authorization: !secret slackbot_token
payload: '{{ payload }}'
I can call the service from the dev page like this:
And I get a message in the logs like this:
2019-11-15 08:26:03 INFO (MainThread) [homeassistant.components.rest_command] Success call https://slack.com/api/chat.postMessage.
So, in short, the only differences I can see between what I have and what you’re doing are:
The way we quote things (which I think is a red herring)
The way we write data into the template dev tool.
I’m also not sure if entering ‘0’ without quotes makes it be treated as an integer. Can you try specifying the data for the service as
and see if that works?
hkapanen
(Harri Kapanen)
November 15, 2019, 3:36pm
6
Ah, turned out it’s not the quotes but the (missing) space after the colon on the data input.
so {id: 0}
instead of {id:0}
