Hi there, I’m really struggling to get my head around this stuff as I’m a total noob, so would love some advice, please… I’m essentially trying to pull a few bits from the Pocketsmith API to display on a dashboard.
Here’s what I have in my config:
rest:
- resource: >
{% set last_day =
31 if now().month in (1,3,5,7,8,10,12) else
30 if now().month in (4,6,9,11) else
29 if now().month == 2 and now().year % 4 == 0 and (now().year % 100 != 0 or now().year % 400 == 0) else 28
{% set first_day = '01' %}
{% set current_year_month = now().strftime('%Y-%m') %}
https://api.pocketsmith.com/v2/users/MY_USER_ID/budget_summary?period=months&interval=1&start_date={{current_year_month}}-01&end_date={{current_year_month}}-{{last_day}}
method: GET
headers:
Accept: application/json
X-Developer-Key: MY_DEVELOPER_KEY
name: Pocketsmith Budget Summary
scan_interval: 86400
- name: "Under by"
value_template: "{{ value_json.x.expense.periods[0].under_by }}"
- name: "Over budget?"
value_template: "{{ value_json.x.expense.periods[0].over_budget }}"
- name: "Under budget?"
value_template: "{{ value_json.x.expense.periods[0].under_budget }}"
This doesn’t throw an error but it also doesn’t show any sensor data at all… There’s a lot going on here so I’m not sure what’s failing. There may even be a better way to do it… but I’m stumped.
This is the endpoint https://api.pocketsmith.com/v2/users/USER_ID/budget_summary?period=months&interval=1&start_date=2022-02-01&end_date=2022-02-31
And here is the json it returns:
"income": {
"start_date": "2022-08-01",
"end_date": "2022-08-31",
"currency_code": "nzd",
"total_actual_amount": 9560.56,
"average_actual_amount": 9560.56,
"total_forecast_amount": 21309.55,
"average_forecast_amount": 21309.55,
"total_under_by": 11748.99,
"total_over_by": 0,
"periods": [
"actual_amount": 9560.56,
"forecast_amount": 21309.55,
"refund_amount": 0,
"current": true,
"over_budget": false,
"under_budget": true,
"over_by": 0,
"under_by": 11748.99,
"percentage_used": 44
"expense": {
"total_actual_amount": -382.5,
"average_actual_amount": -382.5,
"total_forecast_amount": -16527.94,
"average_forecast_amount": -16527.94,
"total_under_by": 16145.44,
"total_over_by": 0,
"periods": [
"actual_amount": -382.5,
"forecast_amount": -16527.94,
"refund_amount": 0,
"current": true,
"over_by": 0,
"under_by": 16145.44,
"percentage_used": 2
