RESTful multiple sensor are not available
I am currently trying to trigger several sensors with the RESTful. However, the sensors are not displayed for the entities.
- resource: !secret bwt_url
  scan_interval: 3600
  headers:
    content-type: "application/json"
    ApiKey: !secret bwt_token
    - unique_id: bwt_state_title
      value_template: "{{ value_json.stateTitle }}"
    - unique_id: bwt_display_name
      value_template: "{{ value_json.displayName }}"
However, if I use json attributes, a sensor.bwt perla is created with all JSON attribute values.
  scan_interval: 3600
  headers:
    - name: "BWT Perla"
      unique_id: bwt_perla
      value_template: "OK"
      json_attributes:
        - displayName
        - stateTitle
What am I doing wrong? How exactly do I read out the individual attributes?
Your indentation is not correct. I’m surprised the second example worked as that is wrong too. Should be:
  scan_interval: 3600
  headers:
Thanks for the quick answer. This a copy paste error. The indentation is correct
Here the direct picture of the config. Do you see a problem here?
Just to isolate the problem, does this work?
  scan_interval: 3600
  headers:
      json_attributes:
        - stateTitle
      json_attributes:
        - displayName
Have you looked at your logs for any error message?
What do you mean by that? Are the sensors created but with no values or you don’t even have the sensors?
Any chance one of those values are bigger than 255 chars?
Nope same issue
No error message in the logs
No the sensors are not created
Nope
Maybe i need resource_template instead auf resource, but i think this is just for the url, correct? There is no template value
What if you remove the unique_id?
Forget that… unique_id should be supported.
Try a debug:
logger:
  logs:
    homeassistant.components.rest.sensor: debug
  • you have to restart HA
@EdwardTFN here is the log
2023-03-14 09:32:27.892 DEBUG (MainThread) [homeassistant.components.rest.data] Updating from https://bwt-real-smarthome-backend.azurewebsites.net/api/Perla/xxxx
2023-03-14 09:56:18.802 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: {"displayName":"BWT Perla Home","stateTitle":"Alles OK!","stateBody":"Ihre Perlwasseranlage läuft einwandfrei.","deviceState":"NotSet","lastTimeDataReceived":"2023-03-14T08:54:15.04+00:00","remainingAmountOfResourcePercent":40,"refillResourceInDays":39,"isHolidayModeActive":false,"scheduledHolidayModeStart":null,"firmwareVersion":2.0012,"waterTreatedTotal":367000}
I have the feeling that the unique ids are not taken, but the name is used.
So i removed this unique_id. Sensor are created now. Can i changed this friendly_name?
If i use it into the sensor i get an yaml error is not supported.
Friendly name is defined by the name key on your sensor settings. You can change that.
What you don’t have control without a unique_id is to change the entity_id (and other settings), which in this case will be the name with all lower cases and replaces non-valid chars by “_”.
Let’s say you set your sensors like this:
  scan_interval: 3600
  headers:
    - name: "Water consumption - State title"
    - name: "Water consumption - Display name"
The system will create:
  • sensor.water_consumption_state_title, with friendly_name: Water consumption - State title
  • sensor.water_consumption_display_name, with friendly_name: Water consumption - Display name.
As I said, if I set the unique-id, it doesn’t work (maybe a bug?)
I would not prefer to have “BWT” as a prefix everywhere in the name. But already in the sensor id this is useful like in the picture :slight_smile:
As I understood from the documentation, unique_id should be supported, so looks like a bug.
And unfortunately without a unique_id your entity_id and friendly_name are necessarily connected. :frowning:
Jip understand. Then i will change the friendly_name direct in the frontend as workaround.
This works:
Should I open a bug report, maybe link to this post?
Why not? :wink:
Why not? :wink:
