I am beginner with REST api. I have a simple task:
on the address http://honeypi.local/backend/measurement.php are values from my sensors. it looks like this:
{"field2":24.6,"field3":64.1,"field5":14.43,"field4":968.3}
the code:
# Example configuration.yaml entry
#sensor:
- platform: rest
resource: http://honeypi.local/backend/measurement.php
method: GET
payload: '{ "weight" : "temperature" : "humidity" : "pressure" }'
does not work. How should the sensor.yaml looks like to get the values to the sensor correctly?
Do i need to create the sensors manually, or will they be created automatically?
Thank you,
Michal, Slovakia
Should be like:
- platform: rest
value_template: "{{ value_json.field2 }}"
unit_of_measurement: "°C"
but the sensor is not appearing.
Troon
(Troon)
October 9, 2024, 6:12pm
3
Is that in your configuration.yaml file? Do you only have one sensor: heading (you should)? Have you restarted HA?
If you have a sensor.yaml file included from the main config file, put the YAML in that file without the sensor: heading, aligned like the other entries.
I have two of them, on different levels. my full configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
#sensor: !include_dir_list sensors
#ZHA Toolkit activation
zha_toolkit:
# Telegram Bot
telegram_bot:
- platform: polling
api_key: !secret telegram_api
allowed_chat_ids: !secret telegram_allowed_chat_ids
# Telegram Notifier
notify:
- platform: telegram
chat_id: !secret telegram_chat_id
- platform: rest
unit_of_measurement: °C
#weewx MQTT
mqtt:
- name: Outdoor_Temperature
state_topic: weather/outTemp_C
unique_id: uniqueid__weather_outtemp_c
value_template: "{{ value | float | round(1) }}"
icon: mdi:thermometer
device_class: temperature
- name: Indoor_Temperature
state_topic: weather/inTemp_C
unique_id: uniqueid__weather_intemp_c
- name: Wind_Speed_weewx
state_topic: "weather/windSpeed_kph"
unique_id: uniqueid__weather_windspeed_kph
unit_of_measurement: "km/h"
icon: mdi:weather-windy-variant
device_class: wind_speed
- name: Wind_Gust_weewx
state_topic: "weather/windGust_kph"
unique_id: uniqueid__weather_windgust_kph
one is for MQTT and one is for rest. if I will remove one of them, the config seems to be invalid - tested through Dev tools.
Troon
(Troon)
October 9, 2024, 6:34pm
5
That looks like it should work. Restart, and if you don’t see it, have a look in the logs. It may be that HA can’t resolve honeypi.local perhaps.
thanks for pointing the direction.
I changed honeypi.local to the IP address, restarted, and! it WORKS
