New to home assistant!
Having read the doc’s I’m trying to get tidal information from the URL below, using the rest platform. But I cant even get the current_time
returned. The Developer Tool -> States for sensor.rest_tide
unknown.
Here’s the returned json from http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?aac=VIC_TP020&offset=false&tz=Australia%2FMelbourne
{ "results": { "current_time": 1574317137, "next_high": { "time": 1574322960, "height": 2.23 }, "next_low": { "time": 1574343480, "height": 0.55 } } }
I think the problem might be that the URL is returning HTML even though it looks like JSON.
- platform: rest
resource: http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?aac=VIC_TP020&offset=false&tz=Australia%2FMelbourne
scan_interval: 30
value_template: '{{ value_json.results.current_time }}'
lolouk44
(lolouk44)
November 21, 2019, 8:11pm
2
something’s wrong with the URL I suspect.
I’ve copied to content of the page in a file and here are the results:
- platform: file
file_path: /config/test1.json
- platform: rest
scan_interval: 30
Thanks for the reply, yes I think the URL is returning HTML and not JSON.
I wonder is there a way to converted using from_json
or to_json
shown here? https://www.home-assistant.io/docs/configuration/templating/#tofrom-json
SteveDinn
(Steve Dinn)
November 21, 2019, 9:50pm
4
Came here to suggest this.
You might be able to use
(value | from_json).results.current_time
I’m thinking the page is just reporting itself as ‘text/html’ instead of ‘application/json’.
lolouk44
(lolouk44)
November 22, 2019, 2:36pm
5
doesn’t work. I think it should really be to_json
but even with just value
it fails.
So I tried with a scrape sensor and I get this:
Access Denied You don't have permission to access "http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?" on this server. Reference #18.8401d417.1574432882.b042b46
Went back to a rest sensor and added header info and “faked” a Chrome user agent and Bingo!
Full sensor declaration:
- platform: rest
name: rest tide_rest
headers:
User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
Content-Type: application/json
tom_l
November 22, 2019, 5:17pm
6
Is there a better way (including my awful regex) to do this?
- platform: rest
resource: http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?aac=TAS_TP003&offset=false&tz=Australia%2FHobart
value_template: '{{ value_json.results }}'
headers:
scan_interval: 21600 # every six hours should be plenty fast enoough.
sensors:
hobart_tide_update_time:
entity_id: sensor.hobart_tides
friendly_name: 'Last Updated'
value_template: >
{{ states('sensor.hobart_tides')|regex_findall_index('\d+')|int|timestamp_custom("%a %H:%M", true) }}
hobart_high_tide_time:
friendly_name: 'Next High Tide At'
value_template: >
{{ states('sensor.hobart_tides')|regex_findall_index('\d+',1)|int|timestamp_custom("%a %H:%M", true) }}
hobart_high_tide_height:
friendly_name: 'High Tide Height'
value_template: >
{{ states('sensor.hobart_tides')|regex_findall_index('(?:[1-9]\d*|0)?(?:\.\d+)',0) }}
unit_of_measurement: m
hobart_low_tide_time:
friendly_name: 'Next Low Tide At'
value_template: >
{{ states('sensor.hobart_tides')|regex_findall_index('\d+',4)|int|timestamp_custom("%a %H:%M", true) }}
hobart_low_tide_height:
friendly_name: 'Low Tide Height'
value_template: >
{{ states('sensor.hobart_tides')|regex_findall_index('(?:[1-9]\d*|0)?(?:\.\d+)',1) }}
It’s ugly but it works:
SteveDinn
(Steve Dinn)
November 22, 2019, 5:18pm
7
What exactly does the state of sensor.hobart_tides
look like?
tom_l
November 22, 2019, 5:20pm
8
{'current_time': 1574442801, 'next_high': {'time': 1574449260, 'height': 1.3}, 'next_low': {'time': 1574471880, 'height': 0.63}}
But (as usual) it’s a string not JSON.
SteveDinn
(Steve Dinn)
November 22, 2019, 5:21pm
9
You can use
{{ (states('sensor.hobart_tides') | from_json).next_high.time }}
etc.
SteveDinn
(Steve Dinn)
November 22, 2019, 5:24pm
10
Oh wait…I just got this. I think if you replace all the single quotes with double quotes, it’ll work.
tom_l
11
Ha! yeah:
Error rendering template: Expecting property name enclosed in double quotes: line 1 column 2 (char 1)
SteveDinn
(Steve Dinn)
November 22, 2019, 5:25pm
12
{{ (states(‘sensor.hobart_tides’).Replace("’", ‘"’) | from_json).next_high.time }}
SteveDinn
(Steve Dinn)
13
ACtually, you can just put |to_json
at the end of the value template in your REST sensor.
tom_l
November 22, 2019, 5:26pm
14
I’ll give that a go.
EDIT: Yep. That did the trick. Thanks Steve.
- platform: rest
value_template: '{{ value_json.results|to_json }}'
headers:
sensors:
value_template: >
{{ (states('sensor.hobart_tides')|from_json).current_time|int|timestamp_custom("%a %H:%M", true) }}
value_template: >
{{ (states('sensor.hobart_tides')|from_json).next_high.time|int|timestamp_custom("%a %H:%M", true) }}
value_template: >
{{ (states('sensor.hobart_tides')|from_json).next_high.height }}
value_template: >
{{ (states('sensor.hobart_tides')|from_json).next_low.time|int|timestamp_custom("%a %H:%M", true) }}
value_template: >
{{ (states('sensor.hobart_tides')|from_json).next_low.height }}
SteveDinn
(Steve Dinn)
November 22, 2019, 5:40pm
15
You may also want to consider using the JSON attributes property on that REST sensor. It’ll break all that stuff out into the sensor attributes if you want.
Just remember that if you can access fields on it, it’s not actually JSON, it’s an in-memory object that is constructed USING the JSON. The default “string” form is python’s native one, which is that weird, single-quoted JSON-like string. To get it to an ACTUAL JSON string, you need ‘to_json
tom_l
November 22, 2019, 5:45pm
16
I didn’t think you could use nested json in restful sensor attributes?
SteveDinn
(Steve Dinn)
November 22, 2019, 5:50pm
17
Hrm…Maybe I’m wrong in that regard, but you have to be careful that the actual state doesn’t exceed 255 characters. The attributes don’t have that limitation.
tom_l
November 22, 2019, 5:58pm
18
Yeah I did check that. It was something like 130 characters for the current readings, so plenty of room for small changes.
Thanks guys for all the input really appreciate it. I’m sure I’ll be able to use your suggestions above to get it working.
In the interests of completeness another approach that I think is close, is to use command_line
combined with an inline python script. I’ve tried two versions;
- platform: command_line
command: python3 -c "import requests; print(requests.get('http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?aac=VIC_TP020&offset=false&tz=Australia%2FMelbourne').json()['results'])"
This tries to use python to dump the JSON i.e. json.dumps(str)
command: python3 -c "import requests; import json; str = requests.get('http://www.bom.gov.au/australia/tides/scripts/getNextTides.php?aac=VIC_TP020&offset=false&tz=Australia%2FMelbourne').json()['results']; print(json.dumps(str))"
Then use a template sensor, (which is NOT working) to display the values;
platform: template
sensors:
six:
value_template: '{{ states.sensor.flinders.next_high.time }} {{ states.sensor.flinders.next_high.height }}'
I feel this approach should work and is close, just need to work out the value_template
part.
Thanks again for you help.
Super work @tom_l and @SteveDinn thanks
