I have some trouble with this sensor:
- platform: rest
unique_id: temperatur_string_rest
resource_template: http://xxx.xxx.xxx.xxx/solar_api/v1/GetArchiveData.cgi?Scope=System&StartDate={{ now().strftime('%d.%m.%Y') }}&EndDate={{ now().strftime('%d.%m.%Y') }}&Channel=Temperature_Powerstage
force_update: true
state_class: measurement
scan_interval: 300
timeout: 30
value_template: >-
{% set value_json_data = value_json.Body.Data["inverter/1"].Data.Temperature_Powerstage["Values"] %}
{% set _last = value_json_data.keys() | list | map('float') | max | string %}
{{ value_json_data[_last] | float(0) }}
unit_of_measurement: °C
I’ve checked everything several times, but unfortunately I can’t find anything anymore. Am I missing something?
Here is the raw data from the api
"Body" :
"Data" :
"inverter/1" :
"Data" :
"Temperature_Powerstage" :
"Unit" : "°C",
"Values" :
"0" : 0,
"10200" : 0,
"10500" : 0,
"10800" : 0,
"11100" : 0,
"11400" : 0,
"11700" : 0,
"1200" : 0,
"12000" : 0,
"12300" : 0,
"12600" : 0,
"12900" : 0,
"13200" : 0,
"13500" : 0,
"13800" : 0,
"14100" : 0,
"14400" : 0,
"14700" : 0,
"1500" : 0,
"15000" : 0,
"15300" : 0,
"15600" : 0,
"15900" : 0,
"16200" : 0,
"16500" : 0,
"16800" : 0,
"17100" : 0,
"17400" : 0,
"17700" : 0,
"1800" : 0,
"18000" : 0,
"18300" : 0,
"18600" : 0,
"18900" : 0,
"19200" : 0,
"19500" : 0,
"19800" : 0,
"20100" : 0,
"20400" : 0,
"20700" : 0,
"2100" : 0,
"21000" : 0,
"21300" : 0,
"21600" : 0,
"21900" : 0,
"22200" : 0,
"22500" : 0,
"22800" : 0,
"23100" : 0,
"23400" : 0,
"23700" : 0,
"2400" : 0,
"24000" : 0,
"24300" : 0,
"24600" : 0,
"24900" : 0,
"25200" : 0,
"25500" : 0,
"25800" : 0,
"26100" : 0,
"26400" : 0,
"26700" : 0,
"2700" : 0,
"27000" : 0,
"27300" : 0,
"27600" : 0,
"27900" : 0,
"28200" : 0,
"28500" : 0,
"28800" : 0,
"29100" : 24,
"29400" : 25,
"29700" : 26,
"300" : 0,
"3000" : 0,
"30000" : 26,
"30300" : 27,
"30600" : 27,
"30900" : 28,
"31200" : 28,
"31500" : 29,
"31800" : 29,
"32100" : 29,
"32400" : 30,
"32700" : 30,
"3300" : 0,
"33000" : 30,
"33300" : 31,
"33600" : 31,
"33900" : 31,
"34200" : 31,
"34500" : 32,
"34800" : 32,
"35100" : 32,
"35400" : 33,
"35700" : 33,
"3600" : 0,
"36000" : 34,
"36300" : 34,
"36600" : 34,
"36900" : 35,
"37200" : 35,
"37500" : 35,
"37800" : 36,
"38100" : 36,
"38400" : 36,
"38700" : 37,
"3900" : 0,
"39000" : 38,
"39300" : 37,
"39600" : 37,
"39900" : 38,
"40200" : 39,
"40500" : 39,
"40800" : 40,
"41100" : 40,
"41400" : 40,
"41700" : 40,
"4200" : 0,
"42000" : 40,
"42300" : 40,
"42600" : 40,
"42900" : 40,
"43200" : 40,
"43500" : 40,
"43800" : 40,
"44100" : 40,
"44400" : 40,
"44700" : 40,
"4500" : 0,
"45000" : 40,
"45300" : 40,
"45600" : 40,
"45900" : 40,
"46200" : 40,
"46500" : 39,
"46800" : 39,
"47100" : 39,
"47400" : 40,
"47700" : 40,
"4800" : 0,
"48000" : 40,
"48300" : 40,
"48600" : 40,
"48900" : 40,
"49200" : 40,
"49500" : 39,
"49800" : 39,
"50100" : 39,
"50400" : 39,
"50700" : 39,
"5100" : 0,
"51000" : 39,
"51300" : 39,
"51600" : 39,
"51900" : 39,
"52200" : 39,
"52500" : 39,
"52800" : 39,
"53100" : 40,
"53400" : 40,
"53700" : 40,
"5400" : 0,
"54000" : 39,
"54300" : 39,
"54600" : 39,
"54900" : 39,
"55200" : 39,
"55500" : 39,
"55800" : 39,
"56100" : 39,
"56400" : 38,
"56700" : 38,
"5700" : 0,
"57000" : 38,
"57300" : 38,
"57600" : 38,
"57900" : 38,
"58200" : 38,
"58500" : 0,
"58800" : 0,
"59100" : 0,
"59400" : 0,
"59700" : 0,
"600" : 0,
"6000" : 0,
"60000" : 0,
"6300" : 0,
"6600" : 0,
"6900" : 0,
"7200" : 0,
"7500" : 0,
"7800" : 0,
"8100" : 0,
"8400" : 0,
"8700" : 0,
"900" : 0,
"9000" : 0,
"9300" : 0,
"9600" : 0,
"9900" : 0
"_comment" : "channelId=65795"
"DeviceType" : 111,
"End" : "2023-11-20T23:59:59+01:00",
"NodeType" : 97,
"Start" : "2023-11-20T00:00:00+01:00"
"Head" :
"RequestArguments" :
"Channel" :
"EndDate" : "2023-11-20T23:59:59+01:00",
"HumanReadable" : "True",
"Scope" : "System",
"SeriesType" : "Detail",
"StartDate" : "2023-11-20T00:00:00+01:00"
"Status" :
"Code" : 0,
"ErrorDetail" :
"Nodes" : []
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2023-11-20T16:41:29+01:00"
