Elgaker
(Peter Elgåker)
October 6, 2021, 9:07am
1
I’m trying to configure a RESTful Sensor that pulls data from a service that consumes Graphql queries. As far as I can tell the service returns an error which leads me to assume that the query (in the payload) is not formatted correctly. The same query works fine from other tools.
My configuration:
- platform: rest
resource: https://api.tibber.com/v1-beta/gql
method: POST
payload: "{ viewer { homes { currentSubscription { priceInfo { today { total startsAt }}}}}}"
json_attributes_path: "$.data.viewer.homes[0].currentSubscription.priceInfo"
json_attributes:
- today
value_template: Ok
headers:
Authorization: !secret tibber_token
Content-Type: application/json
User-Agent: REST
The log gives me this:
2021-10-06 08:13:02 DEBUG (MainThread) [homeassistant.components.rest.sensor] Data fetched from resource: {“error”:“syntax error”}
2021-10-06 08:13:02 WARNING (MainThread) [homeassistant.components.rest.sensor] JSON result was not a dictionary or list with 0th element a dictionary
Please advice
koying
(Chris B)
October 6, 2021, 10:57am
2
Prove it with curl
According to https://graphql.org/learn/serving-over-http/ , graphql with POST should use proper JSON, not the GQL syntax.
Elgaker
(Peter Elgåker)
October 6, 2021, 11:34am
3
Many thanks @koying , changing the post body to proper JSON solved the problem.
payload: ‘{ “query”: “{ viewer { homes { currentSubscription { priceInfo { today { total startsAt }}}}}}” }’
You saved my day!
Why not use the Tibber integration? Tibber - Home Assistant
Elgaker
(Peter Elgåker)
November 3, 2021, 8:56pm
5
@Danielhiversen , as far as I understand the Tibber integration delivers the prices in “real time” as a sensor. Using the method above I’m able to load future prices for the whole day and plot them in advance like below.
Mario2
November 17, 2021, 8:32pm
6
Thanks a lot!
I’ve been looking for a nice way to solve this. Future price is quite handy when planning when to consume power the coming day.
How do you get the price data represented in HA? I get a proper sensor that only holds the state OK (value_template)…
I get the following log message: [homeassistant.components.rest.sensor] JSON result was not a dictionary or list with 0th element a dictionary
I do get a proper response from the API using this curl command:
curl -H "Authorization: Bearer XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" -H "Content-Type: application/json" -X POST -d '{ "query": "{viewer {homes {currentSubscription {priceInfo {current {total energy tax startsAt }}}}}}" }' https://api.tibber.com/v1-beta/gql
Any ideas?
Yeah, sorry about that…
The response looks like this: {“data”:{“viewer”:{“homes”:[{“currentSubscription”:{“priceInfo”:{“current”:{“total”:2.5427,“energy”:2.0262,“tax”:0.5165,“startsAt”:“2021-12-17T09:00:00.000+01:00”}}}}]}}}`
koying
(Chris B)
December 18, 2021, 9:42am
11
And what is your actual sensor definition?
Should work with the OP definition (after fixing the payload).
Here is the sensor config:
- platform: rest
method: POST
payload: '{ “query”: “{ viewer { homes { currentSubscription { priceInfo { today { total startsAt }}}}}}” }'
json_attributes:
- today
value_template: Ok
headers:
User-Agent: REST
koying
(Chris B)
December 19, 2021, 12:00am
13
Oh, misunderstood you I think.
If you want the price as sensor state, you have to adapt value_template to extract it.
Bazillion examples in the forum and in the doc.
Ahhh… OK.
Do I then have to create one sensor for each hour into the future?
intose
(Torfi)
August 20, 2022, 2:01pm
15
I have been struggeling with this and get the same error in the logs, any idea as to what I am doing wrong?
My config
- platform: rest
method: POST
payload: "{ 'query': '{ viewer { homes { currentSubscription { priceInfo { today { total startsAt }}}}}}' }"
json_attributes:
- today
value_template: Ok
headers:
User-Agent: REST
I know this an old topic, but wanted to post here anyway. The following configuration is working for me:
in configuration.yaml create
rest: !include rest.yaml
rest.yaml
- resource: https://api.tibber.com/v1-beta/gql
method: POST
payload: '{ "query": "{ viewer { homes { currentSubscription { priceInfo { current { total energy tax startsAt }}}}}}" }'
headers:
Authorization: !secret tibber_api
User-Agent: REST
- name: "Tibber energieprijs huidig"
json_attributes_path: "$.data.viewer.homes[0].currentSubscription.priceInfo.current"
value_template: "{{ value_json.data.viewer.homes[0].currentSubscription.priceInfo.current.total | float }}"
json_attributes:
- total
- energy
- tax
- startsAt
unit_of_measurement: EUR/kWh
device_class: monetary
state_class: measurement
finally I found a thread on graphQL… but I am still stuck
trying to configure a rest sensor for this Query and following https://graphql.org/learn/serving-over-http/#post-request:
query MarketPrices {
marketPricesElectricity(startDate: "2021-10-01", endDate: "2021-10-30") {
till
from
marketPrice
priceIncludingMarkup
marketPricesGas(startDate: "2021-10-01", endDate: "2021-10-30") {
from
till
marketPrice
see: Get Frank Energie prices with Python and GraphQL
All I can stumble my way through is:
- platform: rest
resource: https://graphcdn.frankenergie.nl
name: Frank energie prijzen
value_template: "ok"
method: POST
# params:
# startDate: >
# {{(now().strftime('%Y-%m-%d')}}
# endDate: >
# {{(now()+ timedelta(days=+1)).strftime('%Y-%m-%d')}}
payload: >-
"query": "MarketPrices",
"operationName": "marketPricesElectricity",
"variables": { "startDate": "2022-10-13", "endDate":"2022-10-14" }
but that leaves out all the attributes
so I should maybe try
- platform: rest
method: POST
# params:
# startDate: >
# endDate: >
payload: >-
json_attributes:
- from
- till
- marketPrice
- priceIncludingMarkup
but would still need a path .
Please have a look if you can help me out, or at least get things going?
thanks!
xned
(Christoffer)
November 24, 2022, 6:54am
18
Looking to do something similar, would you care to share your sensor and what dashbord card you are using for representation?
xned
(Christoffer)
November 24, 2022, 6:57am
19
Nevermind, you start the thread with the sensor, to early and to little coffee
