Hello i’m new here…
How can i extract the temperature off this string?
"variable": {
"name": "TempQnap.temperature",
"readonly": true,
"type": "attribute",
"value": 47,
"unit": "°C"
"success": true
thanks
Chris
Hello i’m new here…
"variable": {
"readonly": true,
"value": 47,
"unit": "°C"
"success": true
thanks
Chris
Try something like:
value_template: '{{ value_json.variable.value }}'
Thanks,
in short:
SOLVED…
mfg
Chris
I’d like to buy the man who thought of value and sensor templates a beer. I keep finding uses for them and learning new ones.
But they do seem to have an impact, especially when initializing after a restart. Are there any best practices for using things like template sensors like a maximum number or should they load before or after other sensors? I just would like to know if they have any negative impacts on performance or anything.
Hi!
I have also problem parsing values…
“ActTime” : 1487175309,
“result” : [
“AddjMulti” : 1.0,
“AddjMulti2” : 1.0,
“AddjValue” : 0.0,
“AddjValue2” : 0.0,
“BatteryLevel” : 100,
“CustomImage” : 0,
“Data” : “7.6 C, 46 %”,
“Description” : “”,
“DewPoint” : “-3.29”,
“Favorite” : 0,
“HardwareID” : 2,
“HardwareName” : “rflink”,
“HardwareType” : “RFLink Gateway USB”,
“HardwareTypeVal” : 46,
“HaveTimeout” : false,
“Humidity” : 46,
“HumidityStatus” : “Comfortable”,
“ID” : “DD01”,
“LastUpdate” : “2017-02-15 17:10:51”,
“Name” : “Außensensor Garten”,
“Notifications” : “false”,
“PlanID” : “0”,
“PlanIDs” : [ 0 ],
“Protected” : false,
“ShowNotifications” : true,
“SignalLevel” : “-”,
“SubType” : “WTGR800”,
“Temp” : 7.60,
“Timers” : “false”,
“Type” : “Temp + Humidity”,
“TypeImg” : “temperature”,
“Unit” : 0,
“Used” : 1,
“XOffset” : “0”,
“YOffset” : “0”,
“idx” : “1”
“status” : “OK”,
“title” : “Devices”
I tried…
value_template: ‘{{ value_json.result.data }}’
value_template: ‘{{ value_json.result.[].data }}’
value_template: ‘{{ value_json.result.[0].data }}’
value_template: ‘{{ value_json.result.Data }}’
The value above are result from domoticz…
bg
Raimund
@piffmasta Did you figure out the parsing on this one?
Yes. Working with jq or nodejs over commandline parsing values… curl xxx | jq xxxx
