Using the rest function i have created a couple of sensors to collect authentication data (this has been changed).
I then want to use this authentication data to query the status in another status, if i add the data manually to the payload then i get returned data but i if i use this data from the states i fail authentication
My “/homeassistant/configuration.yaml”
rest:
- resource: "https://MY-LOGIN-URL/login"
scan_interval: 172000
method: POST
payload: '{"email":"[email protected]","password":"MYPASS"}'
- unique_id: 288cf0be-36d5-4462-8630-9c89b1a6c044
value_template: "{{ value[:205] }}"
- unique_id: 2e1ee29e-6ec2-4733-8732-66e8e4ad3e1e
value_template: "{{ value_json.data.api_token }}" ##example returns (f5354cf4251832edc3b26d82b465c646)
- unique_id: b49e9102-63d0-44a0-9eed-a22a39c4f800
value_template: "{{ value_json.devices[0].did }}" ##example returns (KlkvwRNNnJNQC4bEnE1uSf)
- unique_id: 2d1bfa11-bba1-42a4-bca0-feba9605f019
value_template: '{"did":"{{states.sensor.hot_tub_login_did.state}}","api_token":"{{states.sensor.hot_tub_login_api.state}}"}'
- resource: "https://MY-STATUS-URL/status"
scan_interval: 10
headers:
Content-Type: application/json
method: POST
{{states.sensor.hot_tub_login_api.state}}}'
payload: '{"did":"KlkvwRNNnJNQC4bEnE1uSf","api_token":"f5354cf4251832edc3b26d82b465c646"}'
- unique_id: cc2c04b2-4837-4599-b002-c682f504971a
The above returns status data form the API
however if i do etiher of the following the request is not authenticated
scan_interval: 10
headers:
method: POST
payload: '{"did":{{states.sensor.hot_tub_login_did.state}},"api_token":{{states.sensor.hot_tub_login_api.state}}}'
---OR---
scan_interval: 10
headers:
method: POST
payload: '{"did":"{{states.sensor.hot_tub_login_did.state}}","api_token":"{{states.sensor.hot_tub_login_api.state}}}"'
---OR---
scan_interval: 10
headers:
method: POST
payload: '{{states.sensor.hot_tub_login_payload.state}}'
I either suspect the rest is running asynchronously and the previous request has not populated the state of the required values before this request is submitted and if this is the case what is the best way to manage it?
also if this is the case is suspect the scan_interval is also not working as it should work on the second update should it not?
OR
i have structured the payload incorrectly? and if so what is the correct structure?
