Hi all,
I’m hoping that I’ve missed something simple with this but the sensors I’ve created will only update when the UI is open (either web-based or mobile).
I have web-server running on a pi zero, using the envirophat as a sensor for temperature, pressure & light level. Everything works fine and the sensors update—but only when the UI is open.
I’ve tried specifying a scan-interval and enabling the force_update config variable but neither of those seems to make a difference.
Any ideas?
My alternative is to redefine the sensors as http sensors and have something like cron periodically send over the values. I thought that would be more cumbersome though.
# SENSORS
- platform: rest
resource: http://XXX.XXX.XX.XX:XXXX
#scan_interval: 120
#force_update: true
json_attributes:
- temperature
- air_pressure
- light_level
- heating_status
value_template: 'OK'
sensors:
thermostat_temperature:
friendly_name: Temperature
value_template: '{{ states.sensor.thermostat_sensor.attributes["temperature"] }}'
device_class: temperature
unit_of_measurement: '°C'
thermostat_air_pressure:
friendly_name: Pressure
value_template: '{{ states.sensor.thermostat_sensor.attributes["air_pressure"] }}'
device_class: pressure
unit_of_measurement: 'hPa'
thermostat_light_level:
friendly_name: Light Level
value_template: '{{ states.sensor.thermostat_sensor.attributes["light_level"] }}'
device_class: illuminance
unit_of_measurement: 'lx'
