Restful switch help
I have the following rest commands:
lounge_enhance_on:
  url: "http://10.1.1.17/YamahaExtendedControl/v1/main/setEnhancer?enable=true"
lounge_enhance_off:
  url: "http://10.1.1.17/YamahaExtendedControl/v1/main/setEnhancer?enable=false"
And the sensor that shows the state of the enhancer:
- platform: rest
  resource: http://10.1.1.16/YamahaExtendedControl/v1/main/getStatus
  value_template: '{{ value_json.enhancer}}'
Is it possible to create a restful switch instead?
I’m reading the docs but not making much sense of them.
I can see clearly how I could use the sensor and commands in a template switch but restful is throwing me for a loop.
Like this?
  - platform: rest
    resource: http://10.1.1.17/YamahaExtendedControl/v1/main/setEnhancer?
    body_on: '{"enable": "true"}'
    body_off: '{"enable": "false"}'
    state_resource: http://10.1.1.16/YamahaExtendedControl/v1/main/getStatus
    is_on_template: '{{ value_json.enhancer }}'
    headers:
      Content-Type: application/json
    verify_ssl: false
I think the issue is that you enable/disable the enhancer with a GET request, however according to the docs the restful switch issues POST requests by default and supports PUT as well but not GET.
Damn. You’re right.
api
Template switch it is then.
But through your post I found out about the Yamaha API, thanks for this :slight_smile: now I’m going to check if my model has this as well.
Here’s the API reference (pdf)
Quick way to check:
http://your_avrx_ip_address/YamahaExtendedControl/v1/main/getStatus
Yeah I already found the API reference when I was checking why your rest switch doesn’t work. just need to get to the workstation for testing.
Ugh. Thought I’d crashed the API. Turns out I was looking at the wrong amp. :man_facepalming:
Awesome, seems like my receiver has the API.
FYI, this is what I ended up with. The update entity service was required to stop the switch bouncing as the restful binary sensor scan interval is too slow:
  switches:
    lounge_amp_enhancer:
      friendly_name: Enhancer
      value_template: "{{ is_state('binary_sensor.lounge_enhancer', 'on') }}"
      turn_on:
      - service: rest_command.lounge_enhancer_on
      - delay:
          seconds: 1
      - service: homeassistant.update_entity
        entity_id: binary_sensor.lounge_enhancer
      turn_off:
      - service: rest_command.lounge_enhancer_off
      - delay:
          seconds: 1
      icon_template: >-
        {% if is_state('binary_sensor.lounge_enhancer', 'on') %}
          mdi:tune-vertical
        {% else %}
          mdi:tune-vertical
        {% endif %}
EDIT: had to add a delay between the rest service calls.
I’d be interested to know if you can get the base extension function to work via the API:
http://{host}/YamahaExtendedControl/v1/main/setBassExtension?enable=true
This API command is the only one I can’t get to function. It works via my learned IR remote command so I’m not sure what is going on.
I don’t think this is supported by my stereo amp, I didn’t see “bass_extension” under http://ip-of-host/YamahaExtendedControl/v1/system/getFeatures
No worries. Thanks for looking.
Ah, no wonder it wasn’t working. I don’t have that method either, I have setExtraBass. Similar but not the same.
Yamaha tech support regarding the API has been excellent BTW. They responded within a couple of business days and knew their product.
