RESTful Switch not reading response
I have two API calls to the same end point. One is with the RESTful switch, and another is from a RESTful sensor.
The sensor works, but the switch fails.
The switch fails with log entries:
Template variable warning: 'value_json' is undefined when rendering '{{ value_json }}'
The actual response from all of these API calls is the same:
{"status":true} or {"status":false}
switch:
  - platform: rest
    name: "LED light switch"
    method: POST
    resource: http://octopi.local/api/plugin/octorelay
    body_on:  '{"command": "update", "pin":"r1", "cmd":"on" }'
    body_off: '{"command": "update", "pin":"r1", "cmd":"off" }'
    is_on_template: "{{ value_json.status }}"
    verify_ssl: false
    device_class: switch
    headers:
      X-Api-Key: 'LONGABC0'
      Content-Type: 'application/json'
  - platform: rest
    name: "LED printer api"
    method: POST
    payload: '{"command": "getStatus", "pin":"r1" }'
    value_template: "{{ value_json.status }}"
    headers:
    scan_interval: 15
Any ideas of what I might be doing wrong?
