niekv
(Niek Veldhuizen)
January 12, 2022, 1:56pm
1
I am trying to controller my Ventilation unit. I got a working curl command that can set ventilation value 3 (max ventilation) and back to 1 (normal ventilation.
a want to make a button to switch in on (to max) and off (to normal). Later i want to user the button with automation bassed on RH in my bathroom. I cant seem to get it to work.
From the commandline I can test the CURL and it works:
curl for max ventilation
curl -X PUT http://IP_ADDRESS/commands.json -H “Content-Type: application/json” -d ‘{“UID0”: 3}’
cur for normal ventilation:
curl -X PUT http://IP_ADDRESS/commands.json -H “Content-Type: application/json” -d ‘{“UID0”: 1}’
What is the sollution?
tom_l
January 12, 2022, 2:13pm
3
The restful switch can only use POST not PUT for control. Can you use that method instead?
niekv
(Niek Veldhuizen)
January 12, 2022, 2:19pm
4
No it needs to be a PUT.
I have no succesfuly created 2 Restfull Commands. How do i get them attached to a button? It would be great to gent an ventilation button
tom_l
January 12, 2022, 2:21pm
5
Then Florian’s suggestion is the way.
Use your two restful commands in a template switch.
Do you have a way of getting the state of the switch?
niekv
(Niek Veldhuizen)
January 12, 2022, 2:31pm
6
Yes i have, that is the second part of my question. I can do a
curl -X POST http://IP_ADDRESS/actuals.json
And gat a whole list of values, including the state of the ventilation.
Normal gives
“UID1”: “2,0”,
Max gives:
“UID1”: “8,0”,
And a whole bunch of other values (temperature and m3 ventulation speed… What can o do with them values?
tom_l
January 12, 2022, 3:09pm
7
Sounds like you should be making a template cover not a template switch.
niekv
(Niek Veldhuizen)
January 12, 2022, 4:14pm
8
I got the switch working. It could be more facy with state reading from the actual device. But maybe out of my leage.
Can I get the vallues returned by the curl -X POST http://IP_ADDRESS/actuals.json action into sensors? And also i need to “translate” some values
I get this info:
“UID0”: “83,2,1,16,0,2”,
“UID1”: “2,0”,
“UID2”: “153,3”,
“UID3”: “199,3”,
“UID4”: “63,0”,
“UID5”: “1,0”,
“UID6”: “63,0”,
“UID7”: “0,0”,
“UID8”: “100,0”,
“UID9”: “96,0”,
How can i get the UID valaes in to sensors?
FPro
(Florian)
January 13, 2022, 7:34pm
9
This way you can create multiple sensors for your endpoint:
You can “translate” your values using templating:
Be sure to read the chapter on how to process incoming data.
Since it seems you are controlling a fan, you can also put everything into one entity for easier control:
