Hi, i have the folllowing configuration to calculate a value based on year.
rest:
- resource: http://192.168.0.14/V?m=1&f=j
scan_interval: 60
- name: "szwp_jan_year_indicator"
value_template: "{{ as_timestamp(value_json.tm) | timestamp_custom('%Y', True) | float }}"
- name: "szwp_jan"
value_template: >
{% if (now().year|float) == (states('sensor.szwp_jan_year_indicator')) %}
{{ (value_json.val[0] | replace(',','.') | float) +
(value_json.val[1] | replace(',','.') | float) +
(value_json.val[3] | replace(',','.') | float) +
(value_json.val[4] | replace(',','.') | float) +
(value_json.val[5] | replace(',','.') | float) +
(value_json.val[6] | replace(',','.') | float) +
(value_json.val[7] | replace(',','.') | float) +
(value_json.val[8] | replace(',','.') | float) +
(value_json.val[9] | replace(',','.') | float) +
(value_json.val[10] | replace(',','.') | float) +
(value_json.val[11] | replace(',','.') | float) +
(value_json.val[12] | replace(',','.') | float) +
(value_json.val[13] | replace(',','.') | float) +
(value_json.val[14] | replace(',','.') | float) +
(value_json.val[15] | replace(',','.') | float) +
(value_json.val[16] | replace(',','.') | float) +
(value_json.val[17] | replace(',','.') | float) +
(value_json.val[18] | replace(',','.') | float) +
(value_json.val[19] | replace(',','.') | float) +
(value_json.val[20] | replace(',','.') | float) +
(value_json.val[21] | replace(',','.') | float) +
(value_json.val[22] | replace(',','.') | float) +
(value_json.val[23] | replace(',','.') | float) +
(value_json.val[24] | replace(',','.') | float) +
(value_json.val[25] | replace(',','.') | float) +
(value_json.val[26] | replace(',','.') | float) +
(value_json.val[27] | replace(',','.') | float) +
(value_json.val[28] | replace(',','.') | float) +
(value_json.val[29] | replace(',','.') | float) +
(value_json.val[30] | replace(',','.') | float) }}
{% else %} 0
{% endif %}
device_class: energy
unit_of_measurement: "kWh"
When i compare
(now().year|float)
with
I got the following result:
Ergebnistyp: number
2022
{{ (now().year|float) }}
Ergebnistyp: number
2022
Any idea what i am doing wrong?
Best regards,
Martin
