Hi!
I’m trying to make a restfull switch in home assistant to controll an esp8266 device which is sending IR commands.
The problem is i cant make homeassistant recognize the state of the switch which results in it instantly turns off and sends the command two times.
My esp8266 code ends with this:
client.println(“Content-Type: text/html”);
client.println("");
client.println("<""!DOCTYPE HTML>");
client.println("<“html>”);
client.print(“on”);
How do i configure the “is_on_template” in my switch config to make it recognize the state of the switch?
Or is it necessary to change the code in esp8266 and make it print something else as reply?
//overb
