Good morning,
due to SSD failure I had to reinstall everything and recover a backup.
To my surprise, it appears that the restore did not recover everything in the bd.
In fact I have lost all the history of the energy panel.
Did I do something wrong?
One question, but at this point why not set the use of mariadb as the database for homeassistant by default?
The backup could be done with a simple script
Tom,
do you mean that even a restore of a Mariadb db presents the problem of the corrupt file?
I have decided to implement mariadb on my hassio, the backup of the db I do it to an external script that runs on my pc, not on hassio.
Now I try to restore tonight’s backup on a pc where I have Mariadb installed.
I just tried to restore tonight’s backup on a pc, not my hassio.
The restore was successful and the check of the db gave a positive result for all the tables.
I repeat, I start the backup from a PC external to my hassio, it is a PC on which I have installed a Mariadb server.
For now, I keep everything monitored.
Thanks in any case for your availability.
Giuseppe
