This is probably not the right category, but I didn’t find anything suitable.
The UI doesn’t come up after an update, and I ran through all the check & rebuild commands I could find. Finally, I wanted to try a backup (btw, there is a LOT of outdated documentation when you search for backup restore with HA).
So now I know that I have to do ‘backup restoe ’. Unfortunately, I can only list the backups on the CLI and there are many and go by too fast to read.
How do I do paging in the CLI? Or sort them by age? Or list latest 3 or somesuch?
I can’t be the first person with that problem. But I don’t see an obvious solution for this problem.
Ok, this link helped (but I still think ‘backup’ should do pagination by itself…)
Hi, I would like to propose an addition to the documentation. I corrupted my existing installation. I could still access CLI (display and keyboard connected to raspberry PI). I had to find the correct backup (fka snapshot) to restore. using ‘HA BACKUP LIST’ scrolled too fast and I never saw the slug of the latest backup. The following steps worked:
in the CLI type login
cd /mnt/data/supervisor/backup
ls -l → find the required backup and note the slug
go back to CLI with exit
back restore <slug>
Worked great with the full backup I had available.
Maybe this can help others as well.
Thanks and all the best, Robert
Next problem: “… is only a partial backup”. I tried two of the bigger and recentlyish files. Both the same fault. How do I know which is a full backup?
D’oh - ok that was a bit stupid of me. HA runs here in a VM and when I connect to it, I start on the HA CLI.
The CLI has ‘backups’ but not ‘more’.
When I ‘login’ it is just the other way round.
But: I can run ‘ha backups | more’ after the login which then works as expected.
I did not think about that.
Btw., my problem was totally unrelated to HA which was running perfectly. Didn’t need the backups…
I’m having an issue performing the steps indicated. The Music Assistant add-on broke my HA entirely… no access to backups or to installed add-ons via the UI. Attempting to restore the latest backup gives me this:
I got the same error for previous backups from that screen shot, too.
As I was typing this… I accessed the UI through the iOS Companion app, and was able to get to the backups area there to perform a restore. Whew. But the above question remains, in case anyone’s run into that.
No, I didn’t. Sorry.
Since I’m runnig HA on Proxmox, I did split some add-ons to own conatainers on Proxmox and backing it up within Proxmox. Seems to go very easy.
Sorry @e-raser i didn’t find any solution. I did work around as discribed in previous post. I’m affraid it will not help you.
Good luck and pls post it if you find something.
Hi! When you say “login” in the first step, what do you mean? Do I have to enter any credentials in my CLI? The same thing happens to me. I don’t know what backups I have, and I need one as old as possible… If you could help me, thank you!
How do you view that list of backups? I followed the steps above, but no list appears. I can only see the SLUGs of the last two backups because it’s too fast.
Hi! What he means is, at the HA> prompt, type “login” and press <Enter>.
But, having done that, step 2 no longer works, at least not with version 2025.10.1. Instead the TAR (Tape ARchive) files are version and date+time stamped. What you should type there is, “ha backups | less” and press <Enter> to get the list of backups and other parameters about them and from which you will get the SLUG that you are after.
