So i made an backup of my homeassistant and made a new fresh install with balena etcher.
I choose the backup restore function and its started to install the backup (200mb),
But the installation never stops, it ran all night but still not finished.
Does it take that long time?
Is there another way to install a backup?
The other way is to flash a new install of Home Assistant, log in with a throw away account (it will be over-written). Install the SAMBA add-on and copy your backup to the new system. On the Settings → System → Backups page press the three dots → reload menu item to make your backup visible. Restore it.
I managed to transfer the file and restored it, but homeassistant still keeps crashing, so i connected a hdmi to the rpi 3b+, and i can see that the rpi crashes becuse of high memory usage, this wasnt a problem earlier but now it is.
What can i do to fix this ?
Should i get a rpi 4 or 5?
I also have a qnap nas, ive seen that homeassistant is avalible there, should i use the qnap instead ?
If so, can i just restore the backup from my rpi?
And how about the z wave and zigbee stick i have on my rpi? Can i just plug them in my qnap and it would work?
A full backup takes about 10 minutes.
A full restore takes about 15 minutes.
HAOS Bare metal on an Intel NUC i3
I suspect that you have minimal RAM to begin with. Restore needs to run a program to unzip the tar backup file and copy the contents to the appropriate folders. If you are on the edge of “enough” RAM, then restore may not work. So do it manually the way @tom_l suggested..
Hardware: install more RAM, or run on better hardware.
Software: work out what is using the RAM and stop using it. Voice Assistant maybe?
I’m pretty sure that is a Container install not a HAOS install (not 100% certain) so that would mean you no longer have access to add-ons and would have to manage your own containers. Also (just my opinion) I like my NAS to just be a NAS.
The pi3B will still run Home Assistant but it is the bare minimum and may not be suitable for more complex installations. See:
I know this thread has been dormant for a while, but I’m running into the same issue.
My HA crashed, so I downloaded a new image through Pi Imager and put it on the same Pi (on another microSD card). I did a drag-n-drop to give it the backup from this morning to restore. I don’t have nearly the automations I want to add at this point and my backups are under 100 MB. I told it to do a full backup. That was 45 minutes ago - maybe a full hour.
I’m wondering if copying the backup to the HA system speeds up access. I thought through the access path for the backup. It’s on a RAID (all SSDs) on an NAS, so the data goes from the NAS, through my desktop, and is uploaded from there to the HA system. Still, I would that wouldn’t slow the system up too much. Does it?
