you might not need to do a restore. from that error, i’m guessing you have a small issue in your configuration.yaml
do you have access to edit that file still? if so, can you look in there and find the http: section and underneath there might be a server_host: section? past that whole http: section here and let’s take a look. xx out any ip information you are sensitive about
