Restore default light effect when turn on RGBW led strip
I have installed some RGBW led strips in my house and some time I use the effect mode in some of my scenes.
The problem is that when I turn them off and then on again I get again the light effect.
I would light to set a default state of the light but I can’t find the right solution. I tried with an automation but it doesn’t work because there is no way the check the effect as condition.
Also it is not fully clear how to set the default values for lights.
https://www.home-assistant.io/integrations/light/
Any hints?
Thank you,
Giulio
