In 2025.12 release devs gave us all a Christmas present of a system-wide default dashboards with an ability to override it on user level.
While the intent is understandably good and is a welcomed change for simple installations, it came with annoying side-effect of lost ability to specify default dashboards on per device-level.
The proposed workaround to create separate user for each device sounds like nonsense, so I put some effort to figure out if anything can be done to get device-specific dashboard selection back.
Fortunately, looking at the code, I was able to identify pretty simple way to do this.
Limitation:
- Enabling this functionality effectively disables system-wide/user-overriden default dashboards: system starts behaving like it was in v2025.11 and earlier.
- Only user-created dashboards can currently be selected as deviceâs default dashboards.
Steps:
- Under /www folder create dashboard folder
- In /www/dashboard folder create device-default-dashboard.js file with following content:
const LitElement = Object.getPrototypeOf(customElements.get("ha-panel-lovelace"));
const html = LitElement.prototype.html;
const css = LitElement.prototype.css;
class DeviceDefaultPanel extends LitElement {
static get properties() {
return {
hass: { type: Object },
narrow: { type: Boolean },
route: { type: Object },
panel: { type: Object },
firstUpdated(changedProps) {
super.firstUpdated(changedProps);
this._getDashboards();
async _getDashboards() {
this._dashboards = await this.hass.callWS({
type: "lovelace/dashboards/list"
this.requestUpdate();
async _dashboardChanged(ev) {
const urlPath = ev.target.value;
console.info("selected", urlPath);
window.localStorage.setItem("defaultPanel", JSON.stringify(urlPath));
await this.hass.connection.sendMessagePromise ({
type: "frontend/set_user_data",
key: "core",
value: {
...this.hass.userData,
default_panel: undefined,
await this.hass.connection.sendMessagePromise({
type: "frontend/set_system_data",
key: "core",
value: {
...this.hass.systemData,
render() {
var val = "";
try {
var val = JSON.parse(window.localStorage.getItem("defaultPanel"));
} catch {}
return html`
<div>
Select dashboard:
<div>${this._dashboards
? html`
<ha-select
.label='Dashboard'
.value=${val}
@selected=${this._dashboardChanged}
naturalMenuWidth
${this._dashboards.length
? html`
${this._dashboards.map((dashboard) => {
return html`
<ha-list-item
.value=${dashboard.url_path}
graphic="icon"
<ha-icon
slot="graphic"
.icon=${dashboard.icon || "mdi:view-dashboard"}
></ha-icon>
${dashboard.title}
</ha-list-item>
: nothing}
</ha-select>
: html`<div class="loading">
<ha-spinner size="small"></ha-spinner>
</div>`}<div>
<pre><button onclick="history.back()">Back</button></pre>
</div>
static get styles() {
return css`
:host {
padding: 16px;
display: block;
customElements.define("device-default-dashboard", DeviceDefaultPanel);
- if not added, add
panel_custom:section to configuration.yaml - Add following under
panel_custom:section:
- name: device-default-dashboard
sidebar_title: Set Device Dashboard
sidebar_icon: mdi:devices
module_url: /local/dashboard/device-default-dashboard.js
- Restart HA
Now you should see new entry on the left:
When selected, it will show drop-down with list of user-created dashboards:
Selecting value from the list will:
- Disable system-wide/user-overriden default dashboards functionality
- Set selected dashboard as default dashboard for the current device.
Note: after you done with all devices, you can hide âSet Device Dashboardâ entry via Profile>User Settings>Change the order and hide items from the sidebar.
